Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi big screen won't stay on!
One week ago, the color green appeared on the screen with skewed horizontal lines, and then turned off. Each time I turn it on the sound is fine, I can barely see an image behind the green color. This last for about 15 seconds and then the tv automacially turns off. It is a 1994 Mitsubishi Big Screen Model TS-5053. I disconnedted the cable, but the probelm persist. Your suggestions and advice would be appreciated.
  • 3 Answers
Its very possible you have a failing resistor r2200
Posted on Dec 07, 2008
I have a slightly arched pink & green line accross the top of the screen.
I am wondering if we have the correct model number listed here? If so with the model listed either something is inside like a spider web or that model uses a optical light engine which "might" be able to do this if bad.
Nov 01, 2012 | Mitsubishi WD-60735 Projection Television
I have a 62 inch mitsubishi ws-65413 and the color comes in the goes out. blue and yellow are in more. what is the problem ?
if colors look skewed and come and go----next time enter the convergence menu on the set and call up advanced---a grid of lines should appear---if skewed when set bad (lines should be yellow) you have a common issue---convergence----the model indicated uses two stk-394-250 chips and both would have to be replaced.
Aug 26, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Color wheel for ws55313
Model indicated here DOES NOT HAVE A COLOR WHEEL- so you might want to enter customer menu and call up CONVERGENCE-THEN advanced convergence---a grid of yellow lines should appear----are they showing blue or red skewed etc?
Other is to look with color off to see if black and white screen or not?
Jun 14, 2012 | Mitsubishi WS-55313 55" Rear Projection...
Hello, I bought an LG 47LH50 HDTV exactly 1 1/2 years ago. Black horizontal lines suddenly appeared one night after getting home from work. Over the past two weeks I've seen it go from 3 lines, to 4...
Hi, I purchased the same model in November 2009. About 2 weeks ago a single horizontal line appeared. Each day another appeared until today when the video went out. Now it displays bands of vertical colored lines like a pastel colored rainbow. Did you find a solution to the problem?
Jun 04, 2011 | LG 47LH50 47 in. HDTV LCD
How do I get rid of purple and green wiggly lines? The black screen that appears when switching between channels was green a couple of weeks ago, that problem stopped after I unplugged the set for a while....
You have a bad LCD control board,It overheats and causes colored lines,screen to darken,or the color go floresent. Also check the power supply for bad caps.
when you have it apart.They usualy go bad on these tv's. It will cause the tv to take longer to come on.Or you have to hit the power button several times to get it on.
Oct 26, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi #VS-45605
We had a blue cone on the screen. We have adjusted the sharpness, contrast, and cross hairs. The cone has almost completely disappeared, but we still have blue shadows. Could this mean a blown color tube?
Any suggestions would be greatly appreciated.
Aug 13, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
MITSUBISHI BIG SCREEN MODEL #VS55707
1. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. IS the set shutting off or the hor. lines?
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
185 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
