Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My flash drive broke.i dont know how to recover my files on it . please i need major help, thank you
  • 4 Answers
For "physically" broken drives, we do next-day data recovery for under $100. ($50 for students)
www.24hourdatarecovery.com
Posted on Jul 05, 2009
How to restore delected files from my usb flash drive
Hi, Even I faced the same problem. I have deleted some of the PDF file from my pen drive and luckily I could get all the files from it. I used Yodot File Recovery software and with the assistance of this software I was able to get all the PDF files. Download free trial version of the software if you want to know how to recover a PDF file. It recovers not only PDF file but also all the files present in the drive.
Nov 23, 2012 | Computers & Internet
Tip
Recover deleted files
This is a tip explaining step by step how to recover deleted data, even if it is already deleted from your recycle bin. Before we start, you need to download the software required to complete this task.
Click HERE to download.
After you have downloaded the software, Disc Digger, all you need to do is to double click on .exe file to run the software. The program will automatically start. Now, for this purpose, I will recover DATA from my Flash drive. Click HERE to read step by step instructions a using a Flash drive.
I will copy some files to my flash drive, format the drive, then recover the Data I formatted. You need to remember that there will be more data recovered than the data I copied, because I have used this flash drive for a while, hence, the other deleted data will also be recovered.
So lets Start!!
For this purpose, I will copy a movie to my Flash drive, format my Flash drive and recover the movie.
Here is what I did:
After I copied the movie and the format was done, I opened Disc Digger, chose the drive on which I want to recover from, and started the recovery. The pictures below will explain the steps I Followed.
To open the application, just click on the extracted icon.
Now, i chose my Flash drive as the drive which i want to recover from, and clicked next to proceed.
I chose the dig deeper option, as this option will recover formated files as well, not just deleted files.
At this point you need to choose what type of file you would want to recover, i chose all file types.
Recovery process in progress. My flash drive is 8 GB in size, the recovery took 5 minutes.
Once the recovery is done, you will receive a pop up, which will state that the recovery is done.
Remember, that once the scan is complete, you need to save the files you have recovered. You need to create a folder in which you want to save the file, I just created a Folder on my desktop. Unfortunately, the name does not recover with the file, so you will need to look through the files recovered and after you have saved the recovered file, you need t rename it.
This software can also be used to recover photos from your SD memory card. Al you need to have is a SD card reader, which plugs into your USB port.
I really hope that you can find this helpful.
Please rate accordingly.
Kind regards
Andrea
on Feb 28, 2010 | Baby Gear
I need to recover my files from my USB manually without downloading software!
yes, you can recover files from usb with some good usb recovery software, recommended asoftech data recovery can recover files from usb. here's a good tutorial you can follow
undelete files from usb drive
Oct 23, 2012 | PNY Electronics - Others
I press file mgr then restore from mem.card .now all message file are deleted how do i retrieve my old message file
I dont know if it can be recovered using this software, but theres no harm in trying. so please try
http://www.4shared.com/file/I-e8oRMQ/RS51B130016.html
step 1:
Do not format your MMC, hard drives, flashdrives, etc.
step 2 :
download the link above and locate the download folder and extract the file. Install and wait till the installation is done.
step 3:
open R-STUDIO software.
insert the MMC and check if what drive do you want to recover.
step 4:
make a new folder for the file you wish to recover then choose it as output folder
step 5:
wait untill the process is done.
DONE!!!
Goodluck, Hope that my solution will help you, please rate my solution if it helps. thanks.
Jun 30, 2011 | Computers & Internet
My hard drive turns on, ( with the white light flashing) but does not connect , and makes unusual sounds
Sounds like a serious failure in either the enclosure or the drive. Please do not continue powering the drive on as most of the unusual sounds drives can make are indicative of a major failure and continuing to run them can worsen the damage.
Please reply back describing the sounds as best you can and let me know if the files on the drive are worth spending money to recover. If not, warranty the drive through iOmega if so, let me know your location and I will refer you into a nearby facility that can assist you in recovering the files.
Hope this helps FixYa,
Chris
Dec 20, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
Cannot open file due to I/O device error!!!
dont worry, you can recover files from WD external hard drive, you need to follow the correct steps, here's a perfect data recovery tutorial for you
Recover files from External Hard drive
The tutorial is very easy to follow as I followed it to get back my files.
Apr 06, 2009 | Western Digital Passport 160GB External...
My flash drive is faulty and i want to retrieve my data
dont panic, try this data recovery program called asoftech data recovery.
http://www.asoftech.com/adr/
I used the program before, it helped me recover my files from pen drive. If it does not work, you may try quick format the pen drive and then use asoftech data recovery program to recover again your files.
Oct 10, 2008 | Computers & Internet
Cruzer Micro 2GB, USB Need to recover data
Recovering your problem will be a process. Please, post back w/ your answers and we'll continue to provide you w/ recommendations for what to do next until your problem has been resolved.
Thank you,
BJ
Apr 06, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
128 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
