Tv convereged Hi, To have my tv converged, is this something that we can do ourself? Is so can you please tell me how to do it? Thanks, Brebay
    Genius:
  • 2,920 Answers
Your best bet is to let a shop do it...it can be a real pain to try to do it on your own
Posted on Nov 25, 2008
My has a double picture with a red ghostly picture in the background. Any information on how to fix the problem? I have changed the cables, viewed the different colors, tv input, and looked over the menu....
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergnce select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the curser (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.Please run the convergence feature on your TV. Its giving you duble image because the red, green, and blue guns are disaligned. By running convergence it will realign the guns properly. You need to run the convergence feature at leat onece a week. Please note this is only for CRT rear projection tv's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to. Please refere to your tv's manual on how to do converegence and how to overlap the crosses because every CRT projection tv is different.
Good luck
Oct 15, 2010 | JVC AV-56WP30 56" Rear Projection...
My 61' sony tv needs a convereger how do i fix that?
Press the Flash Focus button on the TV to adjust the convergence of the TV,
Jul 21, 2010 | Sony Televison & Video
Philips 60PP9202-17F Green and Red color across screen How can we fix it ourself
Hi dcwadsworth
What you seem to have is a convergence problem.
If you have a picture with something that looks like 3D effects then some parts will need to be replaced.
I`m leaving you an address where you`ll find everything you need;
http://www.tvrepairkits.com/xcart/home.php?cat=3651
The convergence kit is what you need.
In case you don`t have the tools to do it , you can find what you need HERE
Hope this help Good luck
Apr 17, 2010 | Philips 60PP9202 60" Rear Projection...
Convergence issue... I tried to manually fix it through the menu option without any luck. The convergence does curve at the top and bottom of the screen.
It seems the solder is broken in Vertical Convergence Amplifiers or it is damage internally. This model has 2 Conv. Amps: 1 for Horizontal (Red, Green and Blue) and 1 for Vertical Convergence output (Red, Green and Blue), if the convergence does curve at the top and bottom, it is because Vertical Converegence output is no good. The Conv. Amp. costs around 20 dlls. Thats why you can not fix it with the Menu option. Good luck!
Nov 13, 2009 | Philips 60PP9202 60" Rear Projection...
Colors on my projection tv are out of aliangment
Yes sometimes moving can upset the converegence, I don't think you have a "perfect focus" button to realign pix..I believe you'll have go into the TV's menu and find the convergence menu (i think it's found under video settings) keep arrowing down until you find the option that reads something to the effect "reset to factory settings" and select it. That will realign the circuits... if you have multiple connections in use like an HD cable box, DVD etc.. you may need to do this reset more than once. In other words go to an hd input do reset, go to SD (standard definition) input and do the reset.
Rustym62
Apr 30, 2009 | Televison & Video
Convergence Menu
If the converegence circuit has failed it wont show up till you fix the TV.
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
Jan 29, 2009 | RCA HD61W66 61" Projection HDTV
Red line runs from middle of screen to right bottom and bends in middle
look the only thing u can do is have someone put the parts in for u the parts alone is 40-$ 60.00 and maybe $ 150 in labor that is all u should have to pay. that is what i would charge a customer to repair there tv set and it can be service right there in your home.i hope this helps marty
Oct 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Tv set 48 inches projector..[jvc]
replace 2 X convergence ICs and align. Maybe burnt resistors as well.
easyab@hotmail.com
Calgary
http://calgaryconvergencerepair.weebly.com/convergence-repair-explanation.html
Jun 16, 2008 | JVC AV-48WP30 48" Rear Projection...
No crosshair on manuel convergence
It may be the fluid in the CRT or convergence chips are bad.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2008 | Philips 51PP9100D 51 in. Television
Televison & Video Logo
Top Televison & Video Experts
