Question about Electrolux Vacuums
Electrolux LE, cord retractor not working - Electrolux Vacuums
  • Mickey Mack Dec 27, 2011
    Set the vacuum on the table, bench, etc. on it's wheels, remove the bag and leave the compartment lid open. All internal components are accessed by removing the two rubber side bumpers on either side of the vacuum. This is done by sliding a wide blade screwdriver at the back of the bumper in between the bumper and the plastic rear of the vac and tapping forward with a rubber mallot. Just be careful.
    After removing the two rubber side bumpers, turn vacuum over on it's back and pull the bottom off but only after pulling about 2 feet of the retractable cord out for clearance. You may then access the cordwinder to replace. I have replacement cordwinders available for you.
    President:
  • 2,992 Answers
This happens when the spring inside the cord reel fails. The reel can't be fixed, but can be replaced. A Google search for Electrolux parts turned up several sources. Here's a link to one company I have dealt with in the past:
http://www.totalvac.com/accessory/parts/EXR-3075ES.html
Replacement isn't too difficult if you're comfortable with hand tools and have some patience. Hope this helps and good luck on the repair!
Posted on Nov 22, 2008
3 Suggested Answers
LizDahl
  • 75 Answers
SOURCE: Power cord will not retract
Your cordwinder is broken take it to your local Aerus Electrolux dealer. If you have any additional problems call Liz at 570-326-1731
Posted on Dec 27, 2007
LizDahl
  • 75 Answers
SOURCE: Electrolux Advantage Series Wiring
What model do you have?
Posted on Jan 29, 2008
Simplicity mode l8526L pull cord wont retract
The retractor has failed. You will have to disassemble the machine, find the retractor and repair/replace it.
Jul 12, 2016 | Simplicity Vacuums
Cord retractor doesn't work
does it retract at all or not at all? or does it not stop when the cord is pulled out any amount?
Oct 20, 2011 | Electrolux Guardian Bagged Canister Vacuum
Cord will not retract?
This is caused by a broken retractor reel spring, you will need to replace the retractor.
Jan 28, 2011 | Electrolux Epic 6500 Vacuum
How do i get in to the back of my vacuum 7000 to repair my cord retractor. thank you Dan
The back won't come off until the top and bottom of the case are separated. This is a job that should only be done by an authorized Aerus Electrolux service tech. You may be try to save money by doing it yourself, but it's not worth the potential problems that could lead to. Improper reassembly can and often does result in more being spent in the long run.
Since disassembly of Aerus and pre-Aerus Electrolux vacuums is proprietary information, it shouldn't be posted on the web.
I know this isn't helpful, but it's the best I can do.
Jan 06, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
ElectroLex Cannister model C101J Cord won't retract, trying to remove hard plastc side strips. Appears to be 'one-way' lock in 'T' channel - suggestions unlock?
Use a screwdriver to pry on the top or bottom of REAR cover. I t is held by 4 prongs that fit into 4 holes in tabs. It took a little effort to do mine but it came off. From there you can access retractor mechanism.
Jan 09, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
S248i canister vacuum: electric cord retractor kaput
It is pretty tough to fix a retractor. Maybe hook direct and wind up the cord manual like uprights.
Sep 14, 2009 | Miele Vacuums
Electrolux EL 7001 Oxygen 3 power cord continually retracts
The button has two parts - the inner part (button) and the outer part (surrounds the button). The press the outer part to deactivate (pop out!) the inner part.
It took me a while to figure this thing out, but I was glad the vacuum wasn't broken.
May 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Cord will not remain OUT..keeps slip-sliding back in
The return is stuck on your cord retractor. Take the machine apart untill you can see the retractor, then there is a button or wire that retracts the cord. If it is stuck in the down possition simply reset it, if it is broke you must replace the complete cord retractor.
Apr 11, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Dec 01, 2007 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
654 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
