Question about Linksys Wireless-G WUSB54G 802.11g/b
Wireless network i have a linksys router and modem installed on my desktop and using it to surf net, i want to set up a wireless lan so enable another desktop to use internet too. got the wireless g network adapter and downloaded the driver but i cant find the network in the setup. do i need to set up a wireless lan with its own name and WEP key ? i thought all i had to do is to connect the hardware and it will auto detect and connect. now i got to find out which network . does it mean that if i buy another compact usb adapter to connect my laptop it wont connect because the network is not up? but i can use internet.
    President:
  • 2,992 Answers
You access the setup screen on a Linksys router by going to http://192.168.1.1 in your web browser. When asked for the username and password, the defaults are a blank username and "admin" for the password. Of course, if you changed them you'll use that information.
On the wireless settings screen, make sure the mode is set to either "mixed" or "G-only".
The default SSID (network name) is "linksys". Change this to something else so you'll be able to easily identify the network when you connect from the wireless computer.
The default wireless channel is 6. From the drop-down list, pick a different one. All Linksys routers start with channel 6, so using a different channel can help prevent interference which slows the network.
Under wireless security, choose "WEP". If your wireless adapter supports it (most do), pick "WPA Pre-shared key" for the mode and "TKIP" for the algorithm. WPA is more secure. (If you really want to, you can disable wireless security. It makes connecting very easy, but then anybody in range could use your network. Let them pay for their own service!)
If you've picked "WEP", enter a passphrase in the box, press the generate button, and record the key that's generated. This will be the key you need to enter in your wireless adapter so it can access the network. (Some adapters let you enter the same passphrase you put in the router and generate the key automatically. If yours does, do that. It's easier than entering the long key value.)
If you picked "WPA", enter the keyphrase in the box. This is what will also go into the wireless adapter.
Save the router settings and close your browser window.
Now when your wireless computer shows you a list of networks you'll know which is yours, and when you try to connect you can give the proper key. Once you've done that, the information is saved so connecting is automatic in the future.
Hope this helps. Your screens may not look the same as mine if your router is a later software version, so some of the terms may be sightly different. But the basic steps and required information will be the same.
Posted on Nov 22, 2008
My daughter gave me this router and I don't know how to properly install it.please reply to ljc15108@comcast.net.Also I don't have the CD.
Please do the following
If you have a internet modem connect the lan cable from the Modem to the router's Wan / Internet Port.
From the Lan port you can connect to the system . Or use wireless fuction to connect computer to router
. If you are using wireless then just scan for wireless network from your system and connect it when the wirelelss network got visible
Thanks
Mar 16, 2011 | Linksys Wireless-G WRT54GS Router...
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
I pushed the reset button on my router and now I have no protection from others with my wireless, how can i protect that?
admin user: blank
admin pws: admin
ssid: linksys
wep : none
to setup wireless
May 04, 2010 | Linksys Wireless-G Broadband Router
Need cd for downloading program
Assuming you are trying to install a router.... routers do not use drivers or software. CD's provided with Routers are generally used to walk you through the installation/setup process. Most Linksys routers are default accessible at 192.168.1.1 via your browser. the default username is admin and the password is usually admin. If this does not work, try resetting the router by pressing the rest button located on the back of the unit (small hole) with a paperclip. hold the button in for about 1 minute and then release it... If you are unlucky enough to have a unit with a flashing power lite, this is a dead unit and is not repairable. Look up your model for more specific instructions on www.linksys.com under the support section.
Apr 12, 2010 | Linksys Wireless-G Broadband Router
Trying to set up LInksys WPS54G, connected as
admin user: blank
admin pws: admin
ssid: linksys
wep : none
to setup wireless
make shure you saved settings on every settings
Feb 12, 2010 | HP LaserJet 1320n Printer
I have the 4 port Linsky Router.I have a Sony laptop connected to a Sony wireless routerI also have a movie download box. When I connect both to the modem separetely,bolth the laptop and the mvie download...
this is because your wireless router is a router, and your linksys is also a router. Both are attempting to do routing, and they're colliding with each other.
Go into your linksys router's settings, and set it's IP address to have the SAME subnet mask as your wireless router, (The third number in the ip address has to be the same)
e.g. if your wireless router is 192.168.0.1, make sure your linksys is 192.168.0.2
if your wireless router is 192.168.2.1, make sure your linksys is 192.168.2.2
After that, turn OFF the dhcp server on your linksys router (do this in the linksys config page).
After that, plug the LAN port of your linksys to the LAN port of your wireless router.
Your linksys will now be acting like a "Switch" which is an extension of your network. Voila!
Dec 06, 2008 | Computers & Internet
Please help...internet won't connect
You may be running into a problem of your ISP only allowing one computer on the internet. while the internet is on can you access the internet from the desktop comcast originally setup?  If so that is more then likely your problem.
I have comcast myself and they told me they do not allow home networks. I fixed that problem by using the mac address cloning feature in my router.
The setup cd is also junk, all you should really need to do is:
1. unplug modem, router, and turn off computers
2. Plug modem into router
3. Plug computers into router (don't worry about wireless right now)
4. Turn on modem, wait 20 seconds or so for lights to set,
5. Turn on router. again wait for lights to set
6. Turn on ONE computer that is hard wired into the router
7 Try to surf the net.
8. If successfull try to connect wireless computers (Without using cd) and see if they surf.
If not call comcast and see if your computers are trying to obtain real-world ip's instead of LAN ip's like they should.
If so, you'll need to enable DHCP on the router.
Jul 18, 2008 | Belkin (F5D7230-4) Router (587009)
I need to hook up and start using a wireless router, can i get some help starting?
hi licking;
what type of wireless router are you using? a linksys? or a dlink?
do you have color coded cables?
try this:
from your modem(the box given to you by your isp), connect a cable from your modem LAN port to the WAN port of your wireless router.
If your going to connect a pc wired to your wireless router, you can connect a cable from your wireless router LAN port to your lan card of your PC.
give more details and ill be happy to help you. :)
Jun 19, 2008 | Computers & Internet
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Linksys Wireless-G WUSB54G 802.11g/b Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
