Question about HP OfficeJet K80 All-In-One InkJet Printer
Will not print from computer to prinjter
I get the message: remove and check the black cartridge.
I have done that and replaced to cartridge. It does not change the message. It faxes and copies but will not communicate.
  • 2 more comments
  • csshulman33 Nov 22, 2008
    the cable has been checked and rechecked
    I have cleaned the cartridge in the machine.
    I have done that. It detects...it just says 'error'
    It still says 'remove and check black cartridge' but it is printing from the computer
  • HP Master
  • 19,396 Answers
Clean the metal sensor inside the printer carriage using cotton and isopropyl alcohol.
Posted on Nov 22, 2008
    Brigadier General:
  • HP Master
  • 3,614 Answers
Unplug all connections.
uninstall the driver and reboot the pc.
after this install again the driver for your printer. put all connections and let the pc detect the printer.
    Sergeant:
  • 276 Answers
This is because ur printer is not detecting ur cartridge..also u said its not working with new cartridges --that is because the copper points that detect ur cartrudge circuit has some dust accumulated and needs cleaning
  • smarttech Nov 22, 2008
    clean the copper point connections where u insert the cartridge if the points of cartridge and printer get connected properly it will detect ur cartridge and ur printer will run fine
    i will tell u how the solve ur communication problem with the printer---the procedure is as follows.:
    1)right
    click the my computer icon
    2)click
    properties and then click hardware n go to device manager.
    3)uninstall
    all usb ports and then scan for hardware changes
    4)ur
    pc will detect your printer and ask for printer drivers
    5)re
    load drivers and your pc will communicate with your printer
    6)for
    reloding install the cd follow the instructions on the screen and click next
    7)restart when the printer is loaded.connect the wires
    and cords properly
    Genius:
  • 1,550 Answers
Check the cable connection from printer to computer .
Cable connection might be damaged.
I have message "Cartridge Error". I have established that the colour cartridge seems to be faulty. It is old and only replaced once because I do not actually need colour, use mainly black printing onl
Hi and welcome to fixya
You can print black pages with the color cartage. HOW ? just when you select the size of the paper A4 then ther is an option of colored printing or black if you have ink in the color cartage then it can be done that you can print black pages with that cartage
thanks hope that will be helpful
Dec 08, 2012 | HP Officejet 5610 All-In-One InkJet...
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
Apr 03, 2011 | HP Office Equipment & Supplies
Just installed a 1200 all in one HP printer and it goes through the motions of printing but nothing is on the paper, i have deleted, reinstalled, check every setting possible, done everything that the...
Many a times the cartridges get empty.There is ink in the cartridges,this ink gets over or many a times dried up.Remove the cartridges and see.There will be a steel color nozzle at the base of cartridge,from where the ink comes out.Touch the tissue paper to that base and see,if there is ink coming out.Actually the ink should come out.There will be two cartridges in the printer.One black and one tri-color.On black cartridge when you touch the tissue paper you will get black ink on tissue.On tri-color cartridge when you touch tissue on its base you will get three colors,that are yellow--- blue and pink.( In printer language its called cyan--- yellow---magenta color).If there is ink in the cartridge then it should print,If you have replace the cartridge,then on its base there is a blue color tape.That tape has to be removed from its base.If the tape is not removed the cartridge will not print.-------- One more thing.Before doing any thing.Just do a self test and see if the cartridges are working. The procedure of self test is as follows:--- " 1) Turn the printer on.2) The power on green light should be steady green,not blinking green. 3) When its steady green at that time.Press the cancel and color button both together. 4) By doing this the green light will flash,and printer will take the paper. 5) On that paper the self test will get printed.But if the printer takes the paper and it comes out empty /blank then its cartridge fault.But if the self test is getting printed,then yes its confirmed that there is communication fault between printer and computer.In this case,replace the usb wire.Try new brand usb wire and see if that is helping.One more thing.When you install the printer driver.At that time never keep the usb wire connected between printer and computer.Only keep one side of usb connected to computer tower.In between the installation procedure.The message will come up on your computer screen" this message reads,connect the usb wire to printer.At that time connect the usb wire".As you connect the usb wire the message will come up on your computer screen.The printer is detected.If this message comes up then only your printer will work.If this message does not comes then,there is any of the three things faulty,that is usb wire,the usb port on printer side or usb port on computer side.If usb wire is faulty you can replace this wire with new and check.Its not a costly wire.But if any of the ports are faulty,then this ports are internally soldered on the main board.This ports needs to be re-soldered.This can be done by any printer/computer repair tech.Its hardly a 10 minute job to re-solder loose usb port. ------------- Try this troubleshooting procedure.This will help. Thanks.Helpmech.
Jan 27, 2011 | HP PSC 1210v All-In-One InkJet Printer
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Psc750 alarm message: remove and check black cartridge.
There seems to be a problem with the cartridge. If it is printing normally, you can either live with the error, or replace the cartridge.
You can try cleaning the contacts with a q-tip and some rubbing alcohol just in case.
Jun 22, 2009 | HP PSC 750 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    OR
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Cartridge problems
    Clean the heads, printer is not reading new cartridge or refilled cartridge. You may also have a paper jam if alignment is affected. Check for little jams, post back if no go lilacgerry xxx
    Dec 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
    Hp Officejet 7110 Not Printing From Computer
    HP 7110 Printer
    The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
    Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
    HP OfficeJet K80 All-In-One InkJet Printer Logo
    20 people viewed this question
    Seeker5211
    Seeker5211
