Gateway M460 won't Boot
I have a problem my laptop wont boot it powers up and thats it if i keep turning it off and on it will eventually boot up and run fine until i power off or close it which puts it in standby mode.I am using windows xp home. any ideas.Thanks
Gateway laptop ne56r43u wont boot up
Do you have any more details? Was it the victim of a fall? power surge?
Jul 16, 2013 | Computers & Internet
Gateway 3522 laptop won't boot up
HDD problem, try to fix boot record and test HDD with Hierens Boot CD
Nov 13, 2012 | Gateway 3522GZ Notebook
Gateway CX 2620 unit won't turn on. Replace motherboard?
If the power LED is on then -
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Sep 01, 2012 | Gateway Convertible CX2620 Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
My computer wont boot correctly
won't boot at all?
it's probably the BIOS settings
go to the BIOS settings by pressing F8 or DEL
go to advanced settings
look for "boot device priority" or something like that
set the first priority device as your harddisk
save & exit,restart,happy computing
the "boot device priority" maybe not placed on advanced setting,each BIOS has different interfaces,just look for something like that,it's easy
Aug 22, 2012 | Gateway NV53A24u Laptop
Gateway m255 laptop cpu fan wont let me boot up
open your laptop up and make sure the fan cabels are in correctly if not push them in if that dosen't work get a new fan for it
Jun 15, 2012 | Gateway M255-E Notebook
Gateway m460 wont power up and battery wont charge!
From the information you provided it sounds like a bad DC jack, first check your power adapter with a volt meter if you have one accessible. If your power adapter is outputting the proper voltage, then within a 95% certainty its your dc jack. You can look at this website here for more info on dc jack repair, if you dont have the proper tools to fix it.
May 15, 2009 | Gateway M460 Notebook
Laptop won't boot after new hdd and memory upgrade
Re-seat the memory and the HDD connector. If no change try the mem modules one by one. If no change try it without the HDD connected to see if there is a problem with the new HDD.
Jan 05, 2009 | Gateway M460 Notebook
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
