Question about Kenmore 24032\24036 Top Load Washer
Spin cycle does'nt work.
It goes through the wash and rinse cycle,drain etc,but does not spin. Please advise. Model.Kenmore.model.110.7104903.
My Coldspot refrigerator model 106.7618400.. The freezer is icing up. It does'nt defrost. Also the lower part is very cold..water turns in to ice. Please advise. Thanks.
  • eondatje Nov 27, 2008
    I replaced the defrost timer, but no luck. I have not checked the basket drive yet. Shall check it out. Thanks for your advce.
  • eondatje May 11, 2010
    Thank you for your response. I have decided to replace these. Thanks anyway.
    Sergeant:
    Champion:
  • 291 Answers
You have a bad basket drive on the washer and with a coldspot the problem will most likely be your defrost timer
Posted on Nov 24, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore he21 washer fill agitates drains but will not spin
Hello;
My name is Peter. I am a retired field service technician.
The model number you gave HE21 comes up as a Maytag hot water tank.
Open the front door of you unit. The model number should be at the top on a tag.
Repost your question with this model number.
Nov 10, 2014 | Washing Machines
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
Does'nt drain or spin what is the problem
What is the model number of your unit?
Oct 31, 2012 | Kenmore Washing Machines
Kenmore 80 series Model # 110.23832100\r\nthe washer fills up agitates, when finished washing it stops pauses a while then starts to spin, you can hear the water going out put it is like it can't pick up...
Hi
If the washer is not draining then it is due to a clogged drain pump, drain filter or a kinked drain hose. Clean the drain hose, inspect if the drain hose is plugged. Also check the connection to the drain pump and make sure wiring is fine. Check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Apr 07, 2011 | Kenmore Washing Machines
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Jan 19, 2010 | Kenmore Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Washer will not Spin during SPIN CYCLES
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
60 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
