Question about Sanyo DP42746 42 in. Plasma Television
My sanyo plasma has no picture or sound ...
My sanyo plasma model number dp4276 has no pic or sound. We tripped the curcit breaker when my son plugged something in. I should have uplugged the tv and tripped it back but we just tripped it back the tv was fine after a couple of mins the tv picture and the power light stayed on. I turned it off and on and nothing but i noticed that the green light i see in the back is not on. I wish i would i have purchases that $100.00 surge protecter. Please help called Sanyo there are no help at all tv is out of warranty. So he told me to take it to repair shop.
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Posted on Jan 24, 2008
  • 6 Answers
SOURCE: Sanyo plasma 42 TV Turn off for no reason
Ok Fellas I found the Problem!
The Problem is the V4 Y-Main Board. This board is located on the left side of the case looking upright from the back. I spoke with may suppliers, and Sanyo all confirming this. Apparently it has been an issue for some time. Sanyo has replaced the V4 Y Main board with a W1 Y main board in newer models. The W1 Board is NOT compatible for us tho. Just to be sure... If your T.V is taken apart (like mine) Disconnect the peripheral cable from the V4 Y Main, and turn on the set. I bet it will power up with audio and channel function just NO picture. When you plug the board back in... POOF set shuts down. Replacement boards are VERY hard to come by. So Happy Hunting!
42' HD V4 Y-MAIN
PCB: LJ41-02760A LJ41-02761A LG92-01200A BN96-03352A
Oh yeah.. just FYI, Sanyo, Phillips, and Samsung all use the same parts. Hopefully that will help your searching.
Posted on Aug 04, 2008
SOURCE: sanyo dp50747 Plasma HD TV
I just had mine fixed and the guy said " ITS THE POWER SUPPLY" tv nows works fine after repairs but my ps3 won't work on this tv any clue or is it just cheap engineering and I just get what I pay for!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jan 25, 2009
  • 135 Answers
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Posted on Aug 23, 2009
  • 1738 Answers
SOURCE: 42' plasma won't show picture or sound.
It is your man power supply board.
Posted on Dec 09, 2009
What would cause my sanyo 32" lcd tv to have vertical stripes in picture. has good sound and good picture except for vertical stripes in picture
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 28, 2017 | Sanyo Televison & Video
When I first turn the AKAI 60 " TV on the picture
Replace the main power supply as the smoothing capacitors are low value due to ageing.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | Akai PDP6065TA 60 in. Plasma TV
My tv just won't come on model dp4276
It has a failed main power supply
Check with your local TV tech on parts cost
Nov 03, 2010 | Sanyo Televison & Video
Curcit breaker triping
chances being this welder is probaby 30 amp. rated and you probably have amp. service at a lower rating change your breakers to 30 amp. or higher or you fuses i do hope this will help you,thank you.
Dec 23, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Green light lit but no sound or picture only had it a year
I am a military spouse and I posted a similar problem way back in January 2009, got frustrated and have started a class action on model DP42746 42 inch plasma. There are too many people with the same experience.
Join in on the class action....and get your money back from this horrible company!
No fees or anything to join in on it.
email: danimimozi@gmail.com
Jun 20, 2009 | Sanyo DP42746 42 in. Plasma Television
No pic no sound, power on
NO PICTURE NO SOUND THAN CHECK THE SESTOM CONTROL IC IT IS FAULTY
Mar 29, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
Top and bottom of the picture is cut off.
look for a button on the remote control that says, "pic size"," zoom","aspect" and scroll through until you get to 16x9, full , fill screen . i can't remember what this model states on the screen.
Feb 19, 2009 | LG 42PC3D 42 in. Plasma Television
No sound and black screen
lets get together, start a list of names and sue companies selling crappy wares at way too high prices! email saryejade@aol.com
Nov 09, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
