Question about Samsung HLM5065W 50" Rear Projection HDTV-Ready Television
Samsung HLM5065W DLP shuts itself off for no apparent reason
I have a Samsung HLM5065W DLP that shuts itself off for no apparent reason. I let the TV sit for a few minutes and it turns on again. I just replaced the lamp a few weeks ago, but the shutoff continues so I can guess that this has nothing to do with the lamp. Any thoughts?
Same problem. Went through the gambit, lamp, color wheel then they said it was the board for $600. Can get a new tv for that. Sent board to company who claims to fix it for $40. Got board back and now nothing works. Filled a complaint with attorney general after hearing others did so and samsung fixed it. Waiting on last effort.
Posted on Aug 05, 2010
  • 76 Answers
I just had the same exact problem. New bulb and all. Tech. said it was the Light Engine assemble was going bad. Here is some photos of the Light Engine.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Posted on Jul 16, 2009
4 Suggested Answers
Axle80
  • 73 Answers
SOURCE: Samsung DLP TV, no picture, has sound
Try replacing the ballast next. Its the small circuit board directly underneath the lamp housing. You can access it through the lamp door. If the ballast is overheating or has a leaking capacitor, the tv won't stay lit for more than a minute or two.
Posted on Mar 23, 2009
SOURCE: Samsung DLP 62 inch turns off by itself after being switched on
I had the same issue but instead of shorting out the sensor, I removed the bulb assembly, cleaned the interior of the assembly and TV the best that I could with a vaccum and small paint brush. Once cleaned, I reinstalled the bulb assembly and the TV has worked for the last eight months with no problem.
Posted on Jun 27, 2009
SOURCE: Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Posted on May 03, 2010
My dlp tv keeps switching itself off
take bulp vent cover off rear of tv. there is a little plastic switch that gets pressed in by this cover. i taped mine in because the cover wasnt pressing it in all the way and causing tv to shut off all the time. havent had a problem since.
Jan 11, 2010 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
Samsung tv is shutting off by itself.
Your DLP bulb is going bad. Get a replacement bulb (about $280 if not covered by warranty) and your problem will be fixed. If not, it will eventually stop working.
Sep 08, 2009 | Samsung DLP HL-P5663W 56" TV
My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
Sep 02, 2009 | Samsung DLP HL-P5663W 56" TV
My samsung DLP hls5687wx xaa shuts off by itself. How do I fix it?
The lamp ballast or Color wheel might be the problem. We have experienced both issues with the tv shutting down. Also check the hours on your lamp as it might be getting old.
Jul 07, 2009 | Samsung 56" Slim-Depth LED DLP HDTV
SANSUNG HD TV
I have the HLM-5065W DLP TV. Replaced lamp 1 year ago. It attemps to start 3 times before shutting down. then all light are flashing. I hear an electrical sparking and I see the bulb flicker but that it. Did the bulb go out again? IF so why so soon. If not what is the problem??
Apr 17, 2008 | Samsung HLM5065W 50" Rear Projection...
Samsung DLP HL-P4663W
could be the lamp, and is about time for a new one
http://fixyourdlp.com/blog/?cat=4
Jan 15, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung dlp rear proj model # HLM5065W
Samsung color wheel fix
http://www.jaGet a new cable if everything else works that is your problem
Jan 12, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP TV Powers Off by Itself
yes i have the same problem i need help
Aug 31, 2007 | Proton MM2701VT 27" TV
Samsung HLM5065W 50" Rear Projection HDTV-Ready Television Logo
214 people viewed this question
Henry  Thomas
Henry Thomas
