Question about Kenmore 24 in. 15932 Built-in Dishwasher
Turn on the dishwasher and it doesn't fill up with water
I have checked water supply and is good, when i turn on it doesn't fill up, looking for a wiring schematic to check pump
    Problem Solver:
  • 10 Answers
Bad or cloged water inlet valve!
Posted on Nov 23, 2008
Tip
How to repair or fix a Dishwasher if it doesn't wash well
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
on Sep 03, 2010 | Dishwashers
Kenmore dishwasher filling with water when not in use
The water inlet valve is defective.Turn off the power and close the valve to the water supply line Remove the kick panel on the front of the dishwasher remove the supply line, the clamp to the supply hose, the electrical connectors, ans the screws holding the valve. Reverse process to reinstall. Turn water on and check for leaks Turn on power and you are good to go
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
Whirlpool Dishwasher Model Du850SWPB3 Changed out Water valve, float switch, Still doesn't fill with water. D/w runs in all cycles , just NO WATER.
What ya need to check is for power coming into the water valve from the control board by using a mulitmeter set to measure ac volts and when the dishwasher is running...during the times the unit is supposed to fill their should be power into the water valve.
If ya do not have power into the valve the control is going to be the problem,if ya do indeed have electric power into the valve during the fill times ya need to check the house water supply and make sure GOOD water pressure is available at THE VALVE
GENE
Sep 30, 2011 | Whirlpool Dishwashers
Bosch SHU4006 UC/06 Dishwasher will not fill with water and timer does not advance. Voltage to Water Valve Solenoid does not toggle when timer knob is manually advanced through all cycles.
If you have power to water valve when it is supposed to fill yet doesn't the water valve is bad, as long as their is a good water supply to the valve. Sometimes espically if it has one of those flexible stainless steel braided hoses something in cabinet could have pinched it,
Good luck,i hope this helps
Gene
Aug 01, 2011 | Bosch SHU4006 Dishwasher
Fdd914 dishwasher error code A10 appears and its not in the booklet
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
My dishwasher is showing error code a10 model ide 1005
Jun 12, 2011 | Dishwashers
Dishwasher runs, but no water
Hi. I will assume that by "running" you are referring to the pump motor turning on, but there is no water entering the unit. If you are really lucky, you may just have a stuck float switch actuator. Look for a mushroom style float in the tub basin, lift up gently and release it, you should hear a very light, but distinct clicking sound as the switch is released. If that sounds alright, move on.
I would check things out in this order.
1: Shut off water supply to the dishwasher and remove the bottom panel.
2: Disconnect water supply from inlet valve
3: Using a basin for the water, slowly turn the supply on and verify that you have a good water supply from the house plumbing. If so, continue.
4: Make sure the unit is off, or just have the door popped open, and disconnect the electrical supply from the inlet valve. With a meter set on VAC, turn the dishwasher on, and check for 120VAC between the two wires going to the inlet valve. Make sure to give it a minute, the control may not power the valve immediately. If 120 Volts are present, replace the fill valve. If not, you will want to verify good wire connections back to the control board, and to be sure, test the float switch for continuity. If that also checks out, replace the control board. Let me know what you find if you get a chance.
Mar 14, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Hooked up new dishwasher and no water to it when turn it on.
Sounds like you're a real DIY (do-it-yourselfer)....great!
Try these steps:
Turn off the water supply valve to the dishwasher. Disconnect the water to the fill valve. Place a shallow pan under the water line and open the water valve slowly. If you have water flowing up to this point, check the power to dishwasher. If no water, check the water supply and anything that might keep water from flowing.
If you have water, then look at the inlet screen to the water fill valve. Sometimes, when a new water supply is hooked up, some sedimentation occurs and gets into the inlet screen at the water valve. Check this and clean it out as needed. Not all units have these screens.
Make sure you have removed any shipping plugs or other items that could prevent the unit from operating.
Jan 13, 2010 | LG Dishwashers
No water supplied
float could be stuck . pull the float inside the dishwasher up and down then try it. could be a bad pump, or angle stop is closed or clogged. if float doesn`t work. turn the water supply line off located under the kitchen sink. make sure it`s off by turning the hot water knob on your kitchen faucet. unplug the unit also under the sink. take the bottom cover off and look for the supply line that goes into the water pump. unscrew the supply line. get a bucket and turn the water supply back on just alittle to see if tou get water coming out. if you do it`s not clogged. so it`s either the pump or it`s the timer switch 9 out of ten times it`s the timer switch. good luck.
Sep 02, 2009 | Magic Chef CDB6100 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
73 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
