My printer keeps saying cartidge jamed - Office Equipment & Supplies
  • mikkigoodall Nov 22, 2008
    its accepting the paper now, but isnt copying anythin the ink is full but isnt printing.
  • 55 Answers
Have u installed ur printer drivers correctly?and let me know the model and company
Posted on Nov 23, 2008
  • 55 Answers
Open the cover as if you would change the cartridge. Then press the little black button . Keep it pressed, push “copy” on the left and then the (print) black button on the right of the lcd. The printer will somehow work and work. Wait until it rests again. Then close the cover and press the black button again. Now it should copy… and print, and so on. Hope it helped. Let me know.
Posted on Nov 22, 2008
Hi, I have a problem with my printer... I refiled the cartridge and the computer says that is still empty. Sorry for my English.... Pls help me if you can...
Hi
Found this, think it's a good explaination.
"HP Printers internally keep track of your cartidges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. However, most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printer has the cartidge's serial number stored in memory. This will reset it."
Hope this helps
Jun 10, 2011 | Office Equipment & Supplies
It says check print cartridge
first of all turn off the printer ... remove the cartidge.... try to clean the slots where the cartidges gets installed as well you will find dotted bronze spots on the cartidges try to clean it... turn on the printer and inser the cartidge... if u still get the error the msg for both the cartidge try putting in a new cartidge id you can and if still there is the messag if might be th problem with printer.... replace the printer....
Apr 30, 2010 | HP PSC 1315 All-In-One InkJet Printer
Keep getting remove and check cartridge, I did this and also checked for paper jam but still won't work.
remove the cartidge from the printer and clean up the bronze dotted spots on the cartidge as well as the place where the cartidge is placed inside the printer... then turn on your printer it will ask you to insert the cartidges .....
hope it will owrk for you if does not you may try another cartidge if does not work either its time to call the Manufacturer and get the printer replaced....
Apr 14, 2010 | HP PSC 2175 All-In-One InkJet Printer
The cartidges are not aligning and the printer keep say the cartriges is jamed, what should i do
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 20, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
I am trying to install a new black ink cartridge #23 and it keep giving me an error message saying left cartidge is installed wrong. I have replaced these cartidges many times and never had this problem.
you may not have it seated properly just take it completely back out and reinstall it and it should work fine if not unplug it and try again
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Lexmark X4530 InkJet Printer
Error code E-90
When turning on the power, the Carriage
Unit collides to the Change Lever
located to the front side of the printer. CAUSE
PF Motor
Ink System
CR Scale
CR Encoder Board
Holder Shaft Unit
OR IT S SAMPLE JUST WHEN YOU OPEN THE SCANNER TRY TO MOVE THE CARRIAGE BY THE GEAR OR SOME PAPER JAME IT DO THIS PROBLEM.
Oct 22, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Printer won't process new catridges. These cartridges have been refilled.
Did you install the original cartridge? if you have the old empty cartridge, try to install it and check the error is empty cartridge..if so the problem is the newly installed cartridge. try to buy the new original one.
Dec 17, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Paper jame
This machine only has 3 or 4 sensors
1- In the paper tray to tell it it has paper
2- right before the toner telling it it has fed the paper or if it jammed
3- at the exit of the fuser
4 it may have another one at the very top where the paper is exiting.
If there is no paper on any of thaose then you have a bad sensor/or it is out of place.
Nov 29, 2007 | HP LaserJet 1320n Printer
k24674
jasbo
jasbo
Marvin
Marvin
