Question about SanDisk 2GB microSD Memory Card
Hi my memory card lock - SanDisk 2GB microSD Memory Card
  • buzzedatl Dec 10, 2008
    new sd card .. put it in the canon sure shot and get memory card error .. card locked
  • ruggb May 11, 2010
    so do u have a question?????????????
    Problem Solver:
  • 15 Answers
It can be unlocked.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of datarecovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3,4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - selectextrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - selectdrive - Next - Create new or replace exiting configuration - Next - Hard drive - Next -Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Posted on Oct 14, 2011
Memory card is write protected CoolPixS6000
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Dec 29, 2010 | Nikon COOLPIX S6000 Digital Camera
Tip
Memory Card Locked / write protected error.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
The Memory card is not detected when locked
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Oct 10, 2010 | SanDisk 2GB microSD Memory Card
My memory card is locked and i forgotten passward
heatman101
Sep 30, 2010 | SanDisk 2GB microSD Memory Card
My memory card is locked and forgotten password
heatman101
Sep 27, 2010 | SanDisk 2GB microSD Memory Card
How to lock memory card
Go to option of memory card & select set password. Now you may setup your password to memory card.
Thanks.
May 31, 2010 | Nokia N72 Cellular Phone
I need to know how to lock my memory card of nokia 6300 mobile
hi,
go to setting.....look for the memory icon of your card...select...it will ask you to put password lock....after activate...
P.s don't forget your password..
please don't forget to rank our answers.
thanks,
Feb 18, 2009 | Nokia 6300 Cellular Phone
Memory card loeck
Have you tired to unlock memory card unlock button ? SD cards do have write protection physical lock. take a look at this pic and unlock it, good luck!028cf96.jpg
Dec 15, 2007 | Canon PowerShot A75 Digital Camera
Memory Unlock code rqd
my micro memory card locked .i foget the parasward.plz help me
Nov 06, 2007 | Nokia 6070 Cellular Phone
SanDisk 2GB microSD Memory Card Logo
124 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
