Question about Acer Computers & Internet
How do I know that the 1gb ram I installed in my acer 3000 is installed correctly and recognized?
    Master:
  • 568 Answers
When you start ur computer right click on my computer go to properties your will at the bottom of that page the ram capacity of ur computer
Posted on Nov 22, 2008
I have an acer m1100 and for some reason any type of 1gb ddr2 memory it put in it just comes up in system properties sayin not useable if i boot wiv the other 512 stick in aswell, dont know why it wont...
Memory modules are fickle mistresses; sometimes you'll need matching modules of RAM for it to be recognized properly. From what I'm understanding, you're trying to boot a module of 1GB and another of 512MB. Try to swap the native 512MB for another 1GB stick and see if it works. As well, it's a good idea to install RAM modules that were manufactured by the same company.
Before you do that, it's important to understand that the RAM modules are very delicate electronics. It's also entirely possible, if you haven't worn sufficient ElectroStatic Discharge (ESD) safety equipment, that static electricity could render a module useless. Performing a RAM swap in a proper environment and with the proper equipment (ESD bracelets, in this case) minimizes the possibility of static electricity junking computer components.
Also possible, albeit rare, is that the module is simply defective out of the box. If this appears to be the case, then you can simply return it with the receipt for a refund or an exchange.
Jun 01, 2011 | Acer Aspire M1100-U1402A Refurbished AMD...
Unit came with 2 256 mem sticks--bought and installed 2 1GB sticks(pc3200,400mhz,84pin,low density,DDR--unit will not boot
The 2 1Gb RAM are either the wrong type or they are incompatible.
Try to use the same brand and speed as the 256 Mb RAM that was installed in your Dell.
Jul 31, 2010 | Dell Dimension 3000 PC Desktop
Dell M60 only recognizes 1GB of ram; used to see 2GB.
Is the memory the same size ?and belive it or not some machines don't reconize ram even thought it is installed ,if it is running good and your os reads the ram
don't worry about it if not let me know
Dec 24, 2009 | Dell Precision M60 Notebook
What is the largest ram i can install into my laptop
Im sure the max ram you can install is 2 gigs. hope this helps.
Dec 03, 2009 | Acer Aspire 3000 Notebook
When upgrading from one 256 K memory module to two 512 modules how do you get the second slot to recognize the second 512 module?
I am sure when you say 256k you mean 256 mb? You should not have to do anything for the computer to recognize it. Almost all computers are set up to automatically recognize memory. When installed and you right click on my computer and select properties how much ram does it say is installed? If it is just shy of 1GB or if says something like 985MB then that would be normal. If it only says 512 or 469MB then you have a problem with the second memory bank.
Oct 28, 2009 | Acer Aspire 3000 Notebook
He,Hi This is Abhishek from India.I wanna 2 attach an external RAM of 512MB.Will it support or not?
Hi Abhishek, not sure what you mean by "external" RAM? If you have Vista then you can use a USB drive as extra RAM using "ReadyBoost" - see link (it is Wikipedia so info could be wrong):
http://en.wikipedia.org/wiki/Readyboost
If you are looking to add additional RAM to your motherboard then the Aspire 3000 will take up to 2GB of DDR333 (2x1GB modules). See link to manual here:
http://www.acer.com.au/acer/service.do;jsessionid=32EF97E2669CCE30553D1F1544312AAA.public_a_14b?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3112&sp=page15e&ctx2.c2att1=92&miu10ekcond13.attN2B2F2EEF=3112&CountryISOCtxParam=AU&ctx1.att21k=1&CRC=3559666452
Sep 12, 2009 | Acer Aspire 3000 Notebook
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Can't upgrade an Acer Aspire 3000 notebook to 2 gb
Thanks for choosing fixya.com
Your not alone in this type of problem. When it comes to computer (laptop especially) they usually have a "Max allowed ram" most times its listed in the back of the manual in small print. Its a way to keep people buying new computers (if your into the conspiracy theories)
Chances are even a bios upgrade would not fix your problem. Mostly BIOS upgrades add support for new boot options, plug and play support, and fixes to bugs in older versions.
You can check aspires/acers website for updates www.acer.com
If they have an update it will comes with documentation as to what the update does.
Hope this helps you out.
Jei
Dec 15, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 wont load past acer splash screen
Thanks for the response, turn it off and remove the battery/power supply, now take one of the cards out, now put the battery/power supply back in and switch it on, if it still does not work, do the same again but put the other card back in and take the other one out, now switch on.
Let me know how it goes.
Cheers
Jun 08, 2008 | Acer Aspire 3000 Notebook
Memory issues acer t180 ud360a, no boot up with all (4) ram slots filled...
i had same problem with mine, i have the acer aspire ast180-ud360a, dont put the same memory next to each other, u have to stagger it, so it looks like
------------> [1gb] [512mb] [1gb] [512mb] <--- correct setup
and not like
------------> [1gb][1gb][512mb][512mb] <--- incorrect setup
Nov 25, 2007 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
