Question about Kitchen Ranges
Oven won't light
The oven in my Admiral Designeer series range/oven will not light. I see no glow when I turn it on.
5 Suggested Answers
huuum
  • 750 Answers
SOURCE: I used the self cleaning
Hello Friends Creek.
Welcome to Fixya
You said, you used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. You then unlocked the door and was able to open the oven door no problem. Later on you went to use the oven, pushed the bake button and the lock light would flash. And you could not get past that to get the oven to come on.
You did the right thing to turn off the electricity and then turned it back on.
Did you wait 5 minutes before turning the power back on?Or just flick it off and on?
You said, the lock light still blinked.
But did it lockup again?
Please send me the model and year of your range.
Huuum
Posted on Oct 02, 2008
SOURCE: admiral gas range 68-2543-80.oven doesnt
I have the same range. It does not have a pilot. It uses an electronic ignitor which generates an electrical spark that lights the burner. The ignitor is located at the back of the burner and should make a popping noise and the spark will be visible to the eye. If none of your burners are working have a professional take a look. This is a potentially explosive device and the gas line should not be tampered with unless you are experienced.
Ex-Sears Tech
Posted on Apr 07, 2009
  • 10865 Answers
SOURCE: The oven does not heat up, the igniter glows
hello. I can help.
If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring.
Note… If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician.
Posted on Jun 13, 2009
erpaalai
  • 999 Answers
SOURCE: I have a series 30 Tappan Gas Range with a broiler
Either a weak ignitor or stuck valve. I tap on the valve with the plastic end of a screwdriver while it is glowing and if it lights the ignitor is weak. If not the valve is stuck and both should be replaced.
eric
Posted on Jul 01, 2009
heatman101
  • 43501 Answers
SOURCE: Gas oven will not light.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Jun 07, 2010
Testimonial: "Thanks! I thought that it may be bad, but wasn't sure since it would glow red."
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
I have a Maytag gas stove model MGR5730BDW. The oven won't light. The broiler works just fine. The bottom ingiter glows orange and gets hot but the burner won't light.
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
MY GAS OVEN WON"T TURN ON, IT MAKES ONE CLICK AND YOU CAN SEE SOMETHING GLOWING IN THERE BUT DOESN"T COME ON
Just because it glows that does not mean it is not bad...
heatman101
Sep 18, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Gas oven won't light. igniter
Hello there i got disconnected pleas reenter the chat
Nov 26, 2009 | Tappan TGF657 Gas Kitchen Range
Top burners work, oven not getting gas electronic ignition comes
The electronic ignition system (a ceramic plate that glows red) lets some power pass through to allow the gas to flwo when it has reached lighting temperature. The ceramic lighter needs replacing. Either that or the general electronic in the stove are shot.
Mar 11, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Caloric oven does not completely light
i would replace the ignitor, although its glowing its not glowing strong enough to allow gas to release, simple repair, part numbr 31939701
Nov 22, 2008 | Kitchen Ranges
I used the self cleaning selection on my Admiral Designer Series gas range. The oven went through the complete cycle of 3 hours. I unlocked the door and was able to open the oven door no problem. Later...
Welcome to Fixya
Huuum
Oct 02, 2008 | Kitchen Ranges
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
