Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Sony Wega stanby light blinks 5 or 6 times
My Sony model KP-51WS520, will not turn on when I power it on the standby light blinks 4 to 6 times then it akes a clincking noice similar to a relay closing and turns off.
  • Anonymous Dec 13, 2008
    When I turn it on, no power and no sound. The standby light initially
    flashes 10 times and then pauses for a couple of seconds and then
    flashes 9 times. Then it stays in the 9 flash, pause, 9 flash, pause,
    infinity loop.
  • Anonymous Mar 17, 2014
    Power Light Blinks 6 times
  • Sony Master
  • 19,396 Answers
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Posted on Dec 01, 2008
My kp-57ws520 standby light blinks 9 times tv does not come on any more it did for a short period of time
I had a similar problem with a sony 60" lcd hdtv. The normal power on light was green. When I had an issue the led would flash about 8 or 9 times. Can't remember exactly. It turned out to be a troubleshooting code. When I researched it, turned out to be the high powered lamp that lights the lcd screen was shot. When this happens you get no picture or sound. It's not a terribly difficult job to replace it yourself. I found a replacement bulb on line by my model number along with instructions on how to replace. You probably get about 4 or 5 years out of a bulb depending on usage. Hope this helps.
Jun 26, 2014 | Sony KP-51WS520 51" Rear Projection...
Sony wega tv kp 51ws520 keeps turning off after the standby red light blinks 10x's
problem with str ic need replacement has an internal short need a tech to do it
Jul 08, 2013 | Televison & Video
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
The standby light just blinks when i try to turn it on and it wont turn on
Count the number of blinks of the standby light. It will bink a count, pause and do it again (Common counts are 2 -9) Give this count to a Sony service center and they can help you know what the issue is. (Probably the lamp)
Apr 17, 2010 | Sony KP-51WS520 51" Rear Projection...
I have a 51 in. Sony model kp-51ws520. when I turn tv on I get sound by no picture. Standby light blinks 5 times then shuts off . If I power it back on, sound no picture then standby blinks 10 times after...
Ck small blue capacitor next to hori output Transistor 2k volts they have been known to go Bad, if its OK replace Both of your STK ICs STK392-110s use 180s Mats has them 1-800-628-1118
Mar 23, 2010 | Sony KP-51WS520 51" Rear Projection...
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KP-51WS520 won't turn on
Something bad in power supply or horiz output.Possible bad gun.Needs a repair shop unless you know electronics.
Jul 07, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
2004 Sony 52" Wega dont turn onnthe stand by light stays flashing. This TV first started by taking long to turn on and now and then would turn off until one day it just didnt turn on and the standby button...
When that model Sony shuts down the LED starts blinking as you say but it is telling you something because it blinks a certain number of times and then pauses and repeats the number of blinks. Count the number and then I might be able to help you narrow down where the trouble is.
Jun 14, 2009 | Sony KP-51WS520 51" Rear Projection...
KP-51WS520 wont turn on - standby & timer lights on constantlly
You need to check supply volts on main micro IC702 on main board of Sony KP-51WS520 TV.
If you have experience of big TV repair then I would recommend to get service manual of TV from any online store and check above said IC supply volts. TV must give error by blinking light in case any problem in drive circuits and if main micro fried, no error signal will be there.
Dec 05, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
1,060 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
