Question about Sewing Machines
New Home Memory Craft 7000 won't run when pressing on foot contro
When I turn my Memory Craft 7000 machine on, it displays Err in stitch width window and 3 in stitch length window. When you press other stitch buttons, nothing changes in display window. When you press on foot control, machine does not even try to turn the wheel. It's like the lights are on but nobody's home. My mother got this machine at an estate sale. It has the books with it and is in a very nice cabinet. I just can't get it to run
Need foot control
Posted on Jun 06, 2010
  • PCMomwad Jan 08, 2011
    My dealer told me this means the A board is dead. It could be fixed but the parts are not available any more.
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
I cannot get my needle to realign to the center. It stays left.
it's possible that the machine may need some type of adjustment from a sewing machine shop
Dec 16, 2015 | Janome Memory Craft MC 9700 Sewing and...
Memory Craft won'e change stitch selection
the machine may need to be serviced to see if it's a computer problem
or mechanical one.
Apr 29, 2012 | Janome Memory Craft 9000 Computerized...
Sewing a topstitch
Top stitching is usually done with straight stitch, ie stitch width on zero and stitch length on 2.5 but it depends on the application and the effect you are trying to get. Normal top stitch is where you might be stitching a facing down on the outside of a neckline, so you might want to stitch about 5mm away from the edge of the fabric. Always stitch from the outside of the garment, the finished side so you can turn on corners and control the fabric. If you have a clear pressure foot, then this will make watching the stitching easier. Not sure what your problem is with this technique so feel free to add more in comments if I've missed something.
Oct 02, 2011 | Janome Memory Craft 5700
Cannot get rid of stitch width safety get double beep
In my case the problem was an error in the User Guide.
Press SET four times so that it displays SET 4. At the bottom right of the screen, where the User Guide shows a blank area, there is a setting for the maximum stitch width. If this is set to 0.0 you can only stitch straight. Change it to the other setting, typically 6.0.
Now go to ADJUST. At the bottom of the screen, the middle control is the actual stitch width, which you can set anywhere from 0.0 to the maximum. Set it to whatever width you want for the zigzag.
Oct 07, 2010 | Husqvarna Designer I
What settings for doing zig zag for satin stitch around applique. I have used 3.5 width and 0.2 length but the fabric has a tendancy to pucker and the stitches sometimes bunch
It depends on a couple of things. Depending on the fabric you're using you might want to use a stabilizer like an iron on tear away. If the stitches are bunching the stitch length might be to tight. Try going to 0.3. if the stabilizer doesn't work. With the stabilizer on, it will keep the fabric firmer so it won't pucker. Make sure you have the decorative stitching foot on the machine with the little indentation for the satin stitch to ride in. If you have the wrong foot on, this will cause bunching too. Let me know if this helps.
Aug 22, 2010 | Janome Memory Craft 4900QC Mechanical...
Is there a trick to attaching the hoop on memory craft 7000
usually the hoops just lock on, but make sure you have the correct foot on first and that there is nothing in the way to stop the hoop sitting correctly
Jun 16, 2010 | Janome Memory Craft 5700
Janome Memory Craft 7000 Sewing Machine- When I turn the machine on it moves the needle position slightly and message comes up Err 4, then it freezes. Any clues ????
My Memory Craft 7000 sometimes does the same thing, if it's very cold. Try warming it up by placing it near a heat source, a vent or a floor heater, for a few minutes. Then it works perfectly.
I've used these machines for over 20 years now, and they're my favorite!
If this doesn't solve your problem, you need to take it in for servicing.
They are work horses, but they do need their maintenance from time to time.
I hope this helps you.
Aug 17, 2008 | Janome Memory Craft 5700
Sewing Machines Logo
347 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
