Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Slow and low heating/temp
My Saeco SuperAutomatica Electronic is from the 1980's. It does not have a model #, but I think it is one of the first superautomatics made by Saeco.
My problem is that it is taking longer and longer to heat up, about 10 min initially and then several minutes between functions. the water temp never goes above 160F, even from the frother for tea. It will however heat up enough when put on steam to froth lattes. Do you think this is a boiler problem or simply a thermostat?
thanks,
Suzy
  • 1 more comment
  • suzybanks Nov 27, 2008
    I cannot find the thermostat model #s that match the ones recommended for my machine because it is old. Are they interchangeable with newer models? Also, my machine has 3 thermostats and both the espresso and hot water are way too low in temp. What exactly should I order?
    thanks again,
    Suzy
  • suzybanks Nov 28, 2008
    I just want to say that Ginko is correct! I opened the machine up and the boiler was full of junk and the element is corroded to the point that there is bare wire. Now I just need to know if elements from a new model will fit my machine. Can you help me with that?
    Thanks Ginko!
    Suzy
  • suzybanks Nov 29, 2008
    I would like to follow up on the replacement part for the boiler and element. I cannot get the link for johnnybeans to work. Is the element attached to the boiler and therefore it and the top of the boiler must be replaced?
    thanks,
    Suzy
    Sergeant:
  • Saeco Expert
  • 223 Answers
Looks like you need a new Brew Temperature Thermostat. Should be around 95-100 degrees Celcius. The temperature is on the thermostat itself. You can find the thermostat at http://cerinicoffee.com/Thermostat_Saeco_espresso_machine.asp
Let us know if there is anything else you need help with:
Cerini Coffee Services
Authorized Saeco Service Center
www.CeriniCoffee.com
Posted on Nov 24, 2008
  • Cerini Coffee
    Cerini Coffee Nov 28, 2008
    You can replace the top half with the original heating element... The new style heating elements will not fit your machine. If you are interested in purchasing the correct boiler contact me at johnny@cerinicoffee.com
    Thanks,
    Johnny
  • Saeco Master
  • 19,396 Answers
When a machine takes a longer time to heat up, this is often due to scale on top of the heating element, try using a descaler product, and running a descale cycle a couple of time.
If it is not a scale problem, then it is usually a faulty thermostat or a faulty element.
When it is a faulty thermostat water gets hotter than normally.
Posted on Nov 23, 2008
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
I plan to purchase the Main Power Control Board for the Vienna Superautomatica and was wondering if you thought the average person could replace such an item. I'm good at electronics, etc. I took this...
I have advice many times that you can invest in many parts like elements, group, plastic tap e.t.a. and with a full descale the machine is good as new and with resonable cost. Electronic board is only damage by humidity in one place of it or with a serius problem in one electric part of the machine, like grinder or group motor or heating element solenoid.
So consider that you replace the above board and if the problem is persist and damage the board again.
That is why I consider that the life of the machine is the life of the board because of the cost buying a new one, unless the machine is less that one year old.
If you dont want to buy a new one I strongly sugest to buy a second hand machine in good working condition the same model and color and beleive me the board is consist like new and definiatly would be less than 400.
Good luck
Mar 26, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Superautomatica will not make a full cup of coffee
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Feb 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
What is the difference between a water tank with & without a magnetic float on a saeco Vienna Superautomatica?
Hi
The magnet tells the machine that the water is low so you don't run the pump dry and cause it to fail. Some Vienna Supers had them and some didn't.
Jan 01, 2010 | Saeco Vienna SuperAutomatica Coffee...
Heat temp and time
Nov 22, 2008 | Saeco Vienna SuperAutomatica Coffee...
WAter is not running through espresso and low temp
I understand that you have ran lots of water through the machines, but you need to descale the espresso machine so that you are sure all the lines are clean and not clogged.
If you need a good descaler you can purchase it http://cerinicoffee.com/Dezcal_descaler_4pack.asp
This is the descaler we use at our location.
Cerini Coffee Services, Inc.
Nov 12, 2008 | Saeco Vienna SuperAutomatica Coffee...
Proble with old model of saeco superautomatica electronic twin
most likely a component, i suggest returning for service or replaceing
Dec 10, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
204 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
eyecam
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
