Question about Car Audio & Video
I need instructions to program all ride messenger board
This unit has a remote and it is of no use without the instructions. The remote is like a tv remote and a lot of buttons.
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
Posted on Jun 21, 2008
whytfang
  • 170 Answers
SOURCE: I need programming instructions for Jensen Remote
Here you go...it took a while but I found the user manual cause I ROCK....that's right say it with me....He...Rocks...hehe...but anyway here is the link address if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
Posted on May 20, 2009
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Posted on Oct 19, 2009
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Posted on Nov 28, 2009
SOURCE: Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
http://resources.jvc.com/Resources/00/00/99/82841ien.pdf
Posted on Jan 10, 2010
I need to replace the remote, uc 7067rya
You should be able to get a universal remote for a ceiling fan at home depot or lowes. Be aware they only sell then WITH the remote and the receiver unit as a package. Be aware, you'll need to check the 4 "dip pin" positions on the receiver unit on the fan itself to program the new remote. Yes, you'll have a spare receiver left in the package unless you choose to install the new one. You may have to remove the fan to do this, as they're usually found in the canopy (where the fan hangs from the box in the ceiling.) Often, the dip switches are just left all "up," however, they could easily have been changed. Some fans are programmable now, and you can test the code without having to check the receiver in the fan (similar to an older TV remote.) If you're using this for a TV, Satellite dish, etc, you'll need to find a compatible one online (not necessarily that model, it's "UNIVERSAL" and follow the instructions that come with it. TV and Ceiling fan remotes operate totally differntly, so if you have a remote that does both tasks, it's fairly new technology, and you'll have to follow instructions for the one you purchase.
Feb 13, 2015 | Universal Remote Control Hampton Bay...
My universal control wont pair with my t.v, i have done everything the instructions say and it still wont work my control is a urc-22b and my t.v is a sanyo, please reply kind regards, aaron
If your remote was built and programmed less than 6 months before the TV was released or the TV is newer than the remote, then the codes in the unit will not include your TV. There is a lag in the codes being provided to the companies that build universal remotes.
Please check the date on the TV, since I see that the remote may have been released in 2006. It could be older than that. (There are requests for help with the remote with November 2006 dates that show up on a google search.) If the remote is older than the TV, try a newer universal remote.
If the TV actually is older than the remote, then try a different universal remote to check if the TV's IR receiver has failed or if the remote has failed. Some TVs can respond intermittently to a remote - hitting the sensor may bring the response back temporarily. Then you may be able to find a replacement receiver (try stores like shopjimmy.com or partstore.com). If hitting the unit works, you could try just resoldering the receiver to the board. (A solder joint that swells and contracts can lose contact between the board and the parts on the board.) When searching for parts, open the TV and find out the part number on the board that needs to be replaced. Some sites may have the part but not list the specific TV model that you have. The parts are often used in several TVs.
I hope this helps.
Nov 19, 2010 | Universal Remote Control Remote Control
I bought a 3-in-one remote control #15-2147 but I lost the instructions how can i program my tv jvc without the manual
need the code number to program an old sharp portable tv to the radio shack 3-in-one remote control
Sep 25, 2009 | Radio Shack (15-2147) Remote Control
I need instructions and codes to program jumbo remote control
Try this, just be patient when programing it might take a couple of minutes to program.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Aug 11, 2009 | Brookstone 538744 Remote Control
LOST REMOTE BUT HAVE UNIVESIL REMOTE BUT CODE FOR BAIER TV NOT LISTED CAN YOU TELL METHE CODE
unfortunately, if the code is not listed, you will need to follow the instructions to program the unit without a listed code.....the remote may not be compatible with the unit you are trying to control, or if it does turn the unit off and on, it may not be able to access all the features.
May 09, 2009 | Televison & Video
Programming my remote
Here is a link for the generic programing instructions for the RCA universal remotes. Scroll down the page for a list of device codes.
Let me know if this is what you were looking for.
http://www.thompsontv.com/rcarc.html
Dec 28, 2008 | RCA RCR311B Remote Control
I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Oct 17, 2008 | RCA Universal Remote Control
5 in 1 Remote by Radio Shack
i have a thirteen inch in durabrand tv i need to figure out how to program my radio shack five in one universal remote but have no book how do i do it
Apr 12, 2008 | Radio Shack 15-2200 Remote Control
Car Audio & Video Logo
342 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
