Question about Kenmore Elite 45986 Front Load Washer
The washer goes everywhere and is very loud
My new Kenmore washer sucks-please help me figure out what is going on before I bring my old washer back. My newly installed washer sounds like ten planes taking off at once and moves all over the floor. It has been balanced and rechecked,but the problem just keeps getting worse. It seems like the back part of the washer has a mind of its own-I have a kenmore frontloader. Would getting a pedestalfor it fix the problem or make it worse. The washer is upstairs and on a rebuilt floor. I have had the washer for only four days.
    Problem Solver:
  • 16 Answers
Try putting a cup of water on top of unit and stand in front and bounce up and down if water moves in cup floor is weak not strong enough for unit.
Posted on Nov 23, 2008
My washer is an older one i think 1981 or 1980 its a Kenmore it leaves my clothes wet and soapy and win it goes on the spin cycle it will make a loud buzzing sound or it will make a loud banging sound and...
wow -- that is old. might be time to just go out and buy a new one. a new machine only costs about $350 to $425,,, the cost of a repair man to come out and fix this problem could be anywhere from $200 to $300 and up,, plus on a old machine such as this -- there is a chance that as soon as you fix one thing that something else breaks. sometimes new saves time and money.
oh' ,, and the problem sounds like the motor might be having trouble engaging the transition box.
c...
Dec 31, 2010 | Kenmore 24032\24036 Top Load Washer
Hi, our kenmore HE topload washer was making a loud noise then it stopped and not working now. What was the cause? Any solution? Is it worth fixing it? Your suggestion is greatly appreciated. Thanks
Hello
Loud noise in a top load washer is usually caused by the bearings going bad however, it really depends on the model# what part# needs replacement. Worth fixing-depends on the age of your washer...you know if its more then 10yrs old and repair will cost you more then 50% of its original cost then you can think what you want to do. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Kenmore HE2 Plus Front Load Washer
During the spin cycle basket vibrates very badly - very rough
I had a similar problem. During the final high spin and there was POW and the drum went funky eating into the plastic. I opened the back of the washer and look things over,.The belt for spinning was intact. I set the washer on a drain/spin option and watched from the front and back. While watching the pulley on the drum and could tell there was a hiccup as it went around. I pulled the pulley off and put on a new pulley. The new pulley was going in a perfect circle to spin the drum. It's not a hard repair, just need a little muscle to loosen the nut holding the pulley on and the same muscle to tighten the nut as much as possible. Hope this helps.
Nov 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My washer is making a loud, clicking noise
One of them underwire garments could be stuck in the pump and eating a hole into it.You should take the cover off and take a look at it in motion without the case.
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
How are clothes getting into pump..kenmore 3.5 front loader
Have you been loading to many clothes in the washer at one time maybe ?
Jul 27, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Loud noise during spin cycle wont agitate
The problem is with your motor coupling. The motor coupling sits between the motor and the transmission and is what connects the two so it will spin. This go bad and break with age and with over loading. It is an easy and cheap repair. They cost around 20 dollars at your local appliance repair shop and are almost always on hand as they are common. To change it simply unplug the washer and tip it back. The pump will be the first thing you see, just remove the two black clips on the pump and push it out of the way. Don't take the hoses off the pump or you will have water everywhere. Next is the motor. Unhook the wire harness connected to it. There are two clamp on the motor connected by 4 screws, (two on each). Remove the screws and then with a flat head screw driver pop off the clamps. When you take off the first clamp you will want to be holding the motor as it is going to drop. Careful not to smash your fingers. The motor coupling is going to fall off with it, probably in pieces. Put your new one on, it only goes on one way, and put everything back together again. You will be back to good as new in no time. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad I could help.
Jan 22, 2009 | Kenmore 15864/15862 Top Load Washer
I heard a splash sound from my washer (it's less than 4 months old) and when I went to look there was soapy water behind is and things on top of the washer was wet. We has a bucket on the top and it had...
I don't quite understand exactly what you mean in this but my guess is that something is stuck in your pump if water is going everywhere. With front load washers you have to make sure that you remove everything from your pockets and in between each load make sure you run your hand between the front door boot. (That's the black rubber thing that is between the basket and the door.) Socks and under ware like to get stuck in there and that is what leads to your pump. These front load washers have a common problem with things getting sucked down into the pump if not properly taken care of. If the pump is clogged with something it won't drain and water will go everywhere sometimes. You will need to remove the front panel that is below the door. You will find you screws between the door and the panel that you need to remove. Once off the pump is right there. Make sure you clamp it off with hose clamps or you will have water everywhere. Then remove it and check for anything stuck in there. If there is a sock or something don't get to surprised, it happens all the time. Just remove the obstruction and put it back together. Make sure though that you check that boot every time you use it or soon it will damage your pump and you will need to get a new one. Let me know if you have any other questions and good luck.
Jan 17, 2009 | Kenmore 22422 Top Load Washer
Loud noise in slow down spin mode.
when it is in high spin then you stop the washer it makes a thumping noise until the basket stops sort of like a flat tire sounds to me like you need a drive block
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Here are the answers to your questions about my washer
Based on your answers your basket drive is out in the unit this is a Major repair $300-$350 or so parts and labor you will have to weight the cost of a new machine verses the repair how old is the machine??
Feb 13, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
62 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
