Question about Creative Labs Zen Micro MP3 Player
Problem with the headphone jack
My headphone jack on my mp3 player seems loose and i lose the vocal part of the music or it sounds far away. The problem goes away if i hole the plug against the back edge of the player. I saw another person with this exact same problem on the same machine.
On some creative mp3 players like my 20g sleek photo, the problem stems from poor design on the solder joint inside the unit. I did a search and found a tutorial with pics on how to take it apart and resolder it. It works now but cosmetically it's not 100%. If it's still under warranty, I think for $20 bucks you can send it back and they'll fix it....goodluck!
Posted on Jan 02, 2007
SOURCE:
So when I listen with my headphones now, they only play the background music (if that makes sense). The music is almost echo-y and sounds far away. I rarely get the main music/singer, and if I do hear...
leezamastre,
It sounds like this might be a setting on whichever MP3 player, or sound device that you are using. You should check for an "EQ" on your device and try setting it to a different setting to make it so you can hear the music and vocals of a song.
Please let me know if you have any other questions about this,
Cheers,
Garbanian
Aug 08, 2011 | Skull Candy Audio Players & Recorders
Well i put music in the mp3 and the music sounds weird. the music dont sound like the music at all. like the sound was changed help!!
This device has fragile connectors in the headphone jack. Most of my headphones don't cause any trouble, but one of them always bends the contacts back so other headphones don't work properly.
Symptoms of this problem are: the sound becomes quiet; some frequencies are muffled or inaudible (especially vocals and mid-range); no stereo effect. To be certain that this problem is with the device and not the headphones, try it with a different set of headphones. If the problem remains, the device is damaged.
Unfortunately, the only solution is to open it up and bend the contacts back into the headphone jack so they can connect to the plug properly. This is an advanced maneuver, and you are very likely to break the device permanently if you attempt it. I've been doing this kind of thing for years, and this device was one of the most difficult to work with. Fixing it will be fun for bonafide hardware hackers, but everyone else will be better off just getting a new one. Give the old device to a kid who likes messing with electronics... they can probably re-purpose the battery and the case. :)
Sep 15, 2010 | Sylvania SMP2012SL 2GB MP3 Player
The sound is distorted - for example on certain songs i can only hear the instruments, and not the vocals. On other songs i can only hear the vocals and half of the instruments, the rest of the music is...
sounds like either the mp3 player or the receiver have SRS (kinda like virtual surround sound) disable or modify this setting. search your instruction manual for more information. hope this helps.
Dec 30, 2009 | Sony CDX-F7710 Car Audio Stereo CD MP3...
In-ear Headphones
Same problem, not a 'speaker problem" from blowing them out. Try just pushing the jack until you feel resistance and maually hold the jack. You should hear "almost all the music and vocals'. Validates the transducers are ok. Some sort of wiring problem shorting to mic.
Jun 27, 2009 | V-Moda Vibe Headphones
I cant hear my music
it's usually the first contact (ground) of the headphone jack module that loses it's elasticity and does no longer touch the headphone plug properly. you can try to pull it back inward from the outside using a dentist tool or a sewing needle. if that fails you have to open the ipod touch and push the contact inward or replace the jack module.
Jun 15, 2009 | Apple iPod touch
MUsic not playing correctly on iPod Touch
this problem is the same with me! i dropped my iPod, but it cracked the screen and i'm pretty sure i haven't dropped it on the jack because im very careful with it!!!
Jun 06, 2009 | Apple iPod touch
No vocals!
Maybe your headphones are pulled out halfway.
Feb 11, 2007 | SanDisk Sansa m240 MP3 Player
Music loud, voice low-pitched
Found your question due to having the exact problem you described. New firmware, format... loaded new music, same problem. While switching to yet another set of headphones the sound got better momentarily. The case doesn't appear loose, but squeeze right next to the lcd and lyra name and the audio was fixed. For some reason the audio was mechanical sounding and the voice was almost non-existant unless pressure was placed on the player where described. I tightened the screw in the retaining strap hole and the one under the USB connector flap and all is well for now. Good Luck!!!!
May 01, 2006 | Thomson Lyra PDP2444 53 MB MP3 Player
Creative Labs Zen Micro MP3 Player Logo
80 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
