Question about RCA F27450 27" TV
RCA Modle # F27450 No picture but has sound
I was watching the T.V. one night and all of a sudden the picture Just shrunk down to a small dot in the center of the screen and the sound stayed on like normal.Then the dot Fadded away. We all thought it was somthing to do with the show we were watching but to no avail we discovered it was not the show at all. This is my second RCA that took a dump. Is it me or just the brand of TV i have been selecting. Maybe I should go to the *** TV"s
SOURCE:
SOURCE: RCA F32665 Shows only gray screen, sound works.
I'm having the same problem. It appears to be some sort of programming issue. Unplug the set for a few minutes, then go through the setup procedure when you plug it back in. This will work for a while, if anyone has a permanent solution please post it.
Posted on Aug 19, 2007
SOURCE: RCA 32 in TV no picture no sound just a beeping noise TV power is on
What was the cost for you to have this problem repaired?
Posted on Dec 28, 2007
Shuttle83
  • 1139 Answers
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Posted on Mar 24, 2008
SOURCE: rca 32v524t chassis-atc010a
replaced,off/on vol,up and down,and channel up and down.
Posted on Jun 23, 2008
  • 159 Answers
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Posted on Apr 13, 2009
First our tv had purple dots now we have about six tiny black dots on the tv screen. We notice we had large purple dots running vertical on our tv screen. A couple of days ago we noticed a small black dot...
well u have stopped ur movies(dvds) to many times and the dots are burn marks on ur screens
if u read ur manual it will tell u NOT to leave a still picture on for to long as it will damage ur screen
i assume u have a PLASMA TELEVISION
if not... sorry cant help u
Nov 20, 2009 | Televison & Video
The the width of the picture on my Monitor is reduced.
hi
you may click the right button of your mouse and go to the properties.From there you can adjust the screen resolution.
Jul 01, 2009 | Computers & Internet
TV wont stay on
Sounds like a short somewhere in there. I see old pre-HD big screen sets going for well under $200 on my local craigslist, so look there for a good replacement, because the repair will cost more.
Or fork over about $500 for a good used HD projection set.
Apr 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
NO PICTURE HAS SOUND
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sylvania 27 in tv picture
It sounds like your vertical has shrunk, causing the picture to look squashed. Most likely a bad component in the vertical output stage.
Dec 19, 2007 | Sylvania 6413TC 13" TV
Sound stays on & picture goes to blank screen
I do not see any reference on this problem and I even checked with Sony. If you are on a cable box, I suspect that is the problem.
Oct 25, 2007 | Sony KP-43T70 43" Rear Projection...
Tv doesn't work
If your projection went down to a single dot in the center then you are most likely at the minimum replacing all three projection tubes due to that dot. It will leave a permanent mark in the center of each CRT and not repairable. The cost on that old set aren't worth it.
Mar 30, 2007 | Sony KP-48S75 48" Rear Projection...
Screen zipped down to dot of light in center and went blank. No audio either
the deflection circuit shut down and i hope it didn't burn the crt's .
Oct 29, 2006 | Toshiba 55H70 55" Rear Projection...
RCA F27450 27" TV Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
