Question about Crosley CR712 Shelf System
Cd wont open
I need help, the CD compartment on my CR712 wont open, so I cant play CDs. am I doing something wrong?
2 Suggested Answers
  • 1067 Answers
SOURCE: crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Posted on Jan 22, 2008
get a butter knife and force the cd tray to open try not to force to hard that it breaks but enough that it might kick in the eject by itself
Posted on Apr 12, 2009
0 characters
1 Points
My karaoke machine will not play CDs
the only suggestion I can offer is clean the laser lens with a Q-Tip and rubbing alcohol gently and allow several minutes to dry, if that fails! the whole assembly will need to be replaced.
Mar 15, 2012 | Venturer CD-2160 Shelf System
My sharp cd-ba200 will barley play cds
Put the player On for few hours or overnight. Now remove the panel and get access to the optical head unit, use a clean ear bud to polish the optical head. If not the optical head is weak and must be replaced.
Mar 14, 2012 | Sharp CD-BA200 CD Shelf System
Hi! I have a problem for reading CDs with an aiwa hifi system
the spindle motor goes bad a lot on these aiwa cd unit
May 12, 2010 | Aiwa NSX-DS55 CD Shelf System
hope it is not too late but have had the same problem, just got around to open up the case and found the problem and was able to fix mine and now it plays fine. My problem was with the cd turn table it was not be feeding the cd into the player causing the m-error..
Dec 07, 2009 | Fisher 9925 Shelf System
Will my autorama crosley cr712 record player work without
The record player will work with out a remote.
The CD will need a remote, for operation control.
The radio will work with out a remote
Nov 04, 2009 | Crosley AutoRama CR712 CD Shelf System
7 cd disc changer will not open or work properly
I took off the top then took off the cover of the CDs and took out the CDs then I took out the cd holders and placed them back in and put the top back on and it works now
May 12, 2008 | Audio Shelf Systems
Well. you may have got a cd jammed or stuck in there. it happened to me. but i didnt know the cd fell into the stereo until one day when i closed the cd tray. it got stuck. so i took it apart and there was a cd in there!
Aug 05, 2007 | RCA RS2635 CD Shelf System
Reading CD message
You can use a CD Cleaner as a first step, if it didn?t work the problem need an expert technician to clean the lens or replace it. Good Luck Toufic Malek
Jun 04, 2007 | Sony CMT-HPX9 CD Shelf System
Technics cd hi-fi
hi bobro, when burning the cds, make sure that you are burning it as an audio cd, as this player does not support mp3 formats, just normal audio cds... hope this helps!
Feb 11, 2007 | Technics SCEH790 CD Shelf System
Crosley CR712 Shelf System Logo
24 people viewed this question
Top Crosley Audio Shelf Systems Experts
Robert Marmorstein
Level 1 Expert
Are you a Crosley Audio Shelf System Expert? Answer questions, earn points and help others
