Question about Weather King 10AJA6001AH Air Conditioner
Color coded wires
Hi our system works great! But during the summer our thermostat broke and replaced it with ritetemp 6022 model. The a/c worked great, but now winter is here and the heater wont turn on. I need to know where I can go to find out what my 4 wires do. I have white, green, red, and yellow. But I understand that they can mean anything. I thought that we connected the wires from the old thermostat the same, but apparenlty not. Pleas help we live in South Texas and are not use to 50 degree weather, My kids and I are freezing.!
Thank You,
Norma
    Problem Solver:
  • 25 Answers
Do you have a heatpump or a gas furnace??
Posted on Nov 22, 2008
I have a ritetemp 8082C, how do I open it to replace the batteries?
To replace the batteries in the Ritetemp 8082C thermostat, first switch the Mode switch to Off and the Fan switch to Auto (if they aren't currently in that state). Press up on the catch on the bottom of the thermostat and swing the body of the thermostat away from the back plate on the wall. The lift up to remove the body of the thermostat from the base. Turn the body of the thermostat over to see the battery compartment at the top of the back of the thermostat.
This is shown in the installation manual in different sections. Removing the body is shown on page 3 (page 4 of the PDF). Changing the batteries is shown on page 6 (page 7 of the PDF). Ritetemp has the manual here: http://www.ritetemp-thermostats.com/80XX/images/8082C_installation_guide.pdf .
I hope this helps.
Oct 28, 2017 | Heating & Cooling
I have the 5 day. 2 day programmable thermostat. Installed in the winter but now that it is summer air conditioner won't come on. Can you please advise?
You should always include model number in requests. More info is better. In general, there is a setting for Heat and cold on cheaper thermostats. Mine is like that. It works for heating in winter and you must switch it to "cool" for summer. I assume you do have an AC unit for summer. Who wired it up? was it ever working? Did it get installed during winter? The wiring may be wrong, there are a lot of possible ways to wire. If you are not good at that (and why would you be here if you were?) better get a tech to check it out. In the old days, Edison might send out a tech for free to advise (not fix) if there is a possibility of short (dangerous).
May 20, 2017 | Heating & Cooling
My Ritetemp thermostat keeps going into override and blowing cool air when the heat is supposed to be on. Anyone know what im doing wrong?
Rite Temp thermostats don't usually work buy a Honeywell thermostat and wire correctly or call a tech. Be sure and mark original wiring or you will need to call a tech
Nov 13, 2014 | Heating & Cooling
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
Ritetemp 6022 programmation manuel Where can i
when the furance turns on it never shut off. how can I fix this.
Dec 08, 2009 | Heating & Cooling
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Need wiring to therostat to install a ritetemp 6022
R-red W-heat G-fan BLUE-A/C R-red wire W- white wire G-green wire BLUE-blue wire
Aug 31, 2009 | Heating & Cooling
Rv air conditioning
You may have to remove your filter & look for a model # of your unit, so we can pinpoint your wiring to the thermostat. Usually the terminals on the thermostats are labeled -RC-RH- etc, and you simply move old to new of the same. A lot of times some manufacturers will use phone cable form AC unit to thermostat, and mix up the colors, that's the reason for going to the AC and see what color is used from there. It could be red from control box, connected to green wire to thermostat for example. Thats where you note it and wire accordingly.(terminal calling for red wire, would now be green) If your stumped, get back to us with that model#.
Jul 12, 2008 | Dometic Rooftop RV Air Conditioner
Rheem furnaace blower stays on
On a furnace the fan is controlled by a computer and a sensor ot a oldstyle fan thermostat. Basically it waits till the furnace heats up a little and then turns it on and after it shuts off it will run till the thermostat cools back down may take a few mins. In cool mode the thermostat controls the fan so it shuts down immediatly. This is why the thermostat asks you if its electric or gas heat. Should have a switch somewhere for this.
Nov 19, 2007 | Heating & Cooling
Weather King 10AJA6001AH Air Conditioner Logo
299 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
