Question about GE WJRR4170E Top Load Washer
Incomplete water emptying following spin cycle
All visible water drains from inside washer. However, at end of spin cycle, if I move the bucked of the washer around I can hear water sloshing around. Also, if the washer is not used frequently, that remaining water will cause a musty odor.
    Novelist:
    Champion:
  • 244 Answers
Your pump is on its way out inside they have a small fan which pushers the water out if that is lose than the pump has to be replaced common fault
Posted on Aug 12, 2007
Started filling, made a loud noise, stopped filling immediately, door wouldn't open. I tried everything to get it to open. Running the spin cycle finally got the door open at the end of the cycle, though...
The washer drain the water if you put on spin. all electronically controlled washer won't unlock the door and or spin if there's water inside the water has to be drained out first.If the basket didn't move(no motor movement) and it finished the cycle, POSSIBLE problem is the motor control board. Motor Control Board 00436461
Nov 22, 2017 | Siemens WFXD5200UC Front Load Washer
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
replace the brushes in the motor _around 20 quid and usually the first thing to start messing up when the brushes get short is the fast spin _UNPLUG IT FIRST. you might also like to clean up the com with a bit of wet and dry
Oct 02, 2012 | Whirlpool Washing Machines
Hoover H160E - stops with lights flashing 4 times (cyclic)... suaully before aspin cycle... appears to be incomplete drain (drains until no water viisble in drum - but still significant water at drain.....
I would definitely change the pump motor judging from your clear symptoms and observations!
It's probable that the motor isn't running efficiently, just enough when helped by the 'gravity' of the full drum but struggles once that is minimum.
Go for it ;-0)
John C
Feb 26, 2011 | Hoover H160E Front Load Washer
My washing machine will not empty of water and this is preventing it from spinning.how do i empty the water via pump filter as i have no manual and it will not let me download one.please help!
This is could be caused from several issues. First I would try changing cycles on the timer to another spin cycle to see if that let the washer drain. Some times the timer malfunctions and doesn't allow the washer to spin. If this doesn't work and you can hear the motor running then you could have a broken belt or bad clutch or a wig wag (electric solenoids that operate the transmission.). The easiest way to empty the washer if it's located near a floor drain is to remove the drain hose from the drain and lay it on the floor near the drain. The water will run right out of the machine. If you not near a drain then you can use a Wet / Dry Shop Vac, remove the paper filter from inside the Shop Vac and then your ready to vacuum out the water. You will need to empty the vac several times.
Or you can use a garden hose and siphon the water out by place in one end in the washer and the other end outside or near a drain, You will need to **** on the end of the hose that's near the drain or outside. This will almost guarantee you a mouth full of laundry water so be careful if you try this.
Aug 05, 2010 | Washing Machines
Water not emptying from the machine,
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Ariston Technologies Ariston AWD12 Front...
You can hear water behind the drum when you spin
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Is some water in the tub of a top loading washer normal?
It is normal to have residual water in the drain lines and pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, you have nothing to worry about.
Some model washers also have a balance ring around the perimeter on top of the wash tub that is filled with fluid. This acts as a stabilizer to help keep the washer balanced during the spin cycle. If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 21, 2010 | Whirlpool WTW5200S Top Load Washer
My Washing machine is retaining water in the bottom or back of the washer which is visible sometimes. It has mildewed and SMELLS! I have run the washer through the spin cycle several times and this empties...
Sounds like your drain hose is pluged with something. Try and check for small idem into drain on bottom of washer ( chain, braclet etc ) or soap buildup. Once you have determined wheather or not there is a plug to be removed, you can run cider vinegar through your wash cycle which will help reduce the mold. Plus it helps with soap clog buildups. Powered soaps tend to build up faster then liquid soaps do.
Feb 25, 2010 | Whirlpool Washing Machines
My washer fills , sits, does not agitate, empties and spins.
I had the same problem. Take the agitator off by pulling on it extremely hard - use allen wrenches in the slots on the sides to help. This exposes the "air bell coupler" - take the 7/16" bolt out and slide it off. Chances are the spline is stripped out inside. The part is 5 bucks online
Feb 01, 2009 | GE WJRR4170E Top Load Washer
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
GE WJRR4170E Top Load Washer Logo
165 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
