Question about Motorola Mobility RAZR V3x Cellular Phone
Faceplate how to change front face plate cover
You can't take the faceplate off you have to buy a snap on cover. This makes the phone thicker but if you want a different look that is what you have to do. You can also buy phone stickers and decorate the front and back.
Posted on Nov 28, 2008
ReMove faceplate
Remove the Outer Case Panel on the side by removing the screws on the back that holds it. Now once one side of the case is removed, look down the front on the metal part of the case. You will probably see the plastic catches or hinges from the face plate, push them in to release them and you can remove the face plate.
Apr 11, 2012 | E-Machines D2046 PC Desktop
How to change from latch with face plate to drive in latch
How do I mount the Face Plate on the Latch?
Insert the latch into the faceplate opening, ensuring that the sides of the faceplate line up with the flat surface on the latch collar. Push flush with the drive-in collar. Then grasp the faceplate in one hand and the latch in the other hand and rotate the faceplate clockwise to snap in to the collar.
Nov 24, 2010 | Weiser Lock Powerbolt 1000 Lock
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Remove schlage deadbolt
Schlage B160 - need small screwdriver to insert at bottom of faceplate to pry cover off. Face plate appears flush, but with a penlight you can see the recess at the bottom to pop it off. Screws lie under the cover for disassembly. Seems to be a lock design improvement once you figure out how to remove the faceplate.
Feb 08, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Replacing the facepale
that hole on that model is for a locking screw, the locking screw is installed to minimize theft and for other precautions. If the face plate is having any odd reactions its normally do to the flex cable. The best sign for a dying or dead flex cable is at the joint. The joint can be viewed at the point when you remove the face plate. Immediately after pulling the face plate off look behind the pivoting frame at the orange colored ribbon, you should only be able to see a small portion of it. If there is any sign of a yellowy residue its a sign that the protective covering of the ribbon is deteriorating. A bad flex cable is everything on the moving face plates.
Sep 06, 2008 | Kenwood KDC-716S CD Player
Nokia 6288 front cover
first lift the side's of the face cover and remove it backwards with the phone facing you, wala....just snap on the new one in reverse order.
May 28, 2008 | Nokia 6288 Cellular Phone
Face plate replacement
You can't find faceplates for card decks since that will defy the safety feature.
Mar 19, 2008 | JVC KD-AVX33 Car Video Player
How to remove face plate
All i did was slip a knife blade between the silver part and where the face plate meets it. It simply pops out after aplying some upward pressure. There are a few places where the face plate has to be popped before the entire thing is free
Oct 12, 2007 | Motorola Cell Phones
How to change my faceplate
The face plate snaps on, unless your talking about changing the front LCD cover. Then I would take it to my local service provider store and let them do it. It's there job.
Jul 02, 2007 | LG C1500 Cellular Phone
Motorola Mobility RAZR V3x Cellular Phone Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
