Question about Sony DVP-NC600 Multi-disc DVD Player
DVD player not working right
I have a Sony DVP-NC600 SD/DVD player - it is about 6years old. Last night it lost the color blue - everything is now green and red. The color on the TV is fine but not the DVD player -- I tried several DVDs and it happened to all of them. Can anyone help?
Check your cables between your DVD player and the TV, this play has component video outputs that could possibly cause this issue.
Posted on Aug 30, 2007
My DVP-NC600 CD/DVD player will not recognize discs inserted. The carosel just spins freely and won't stop. HELP!
Welcome to fixya!
open up the screws , if you can check the tray if there is something inserted remove it and its ready to be used again ,
the reason is something is struck inside it may be a disk or something .
Check if helps you in any manner
Apr 30, 2011 | Sony DVP-NC600 Multi-disc DVD Player
Hooked up dvd sr200p to bravia..no color...
If you are connected useing the component video cords (red,blue,green,red,white) it sounds as if you have the red,blue or green cords connected to the wrong color of jacks on the back of the TV or the DVD player, recheck your connections.
If all is good there, maybe one of those cords are bad?
The Sony DVP-SR200P DVD player is on the bottom end of their model line up, and you may have received a bad one right out of the box!
GOOD LUCK !!
Aug 03, 2010 | Sony DVP-SR200P DVD Player
Sony 5 changer dvd player won't work. displayed code 31
Hi:
This may be caused by one or two causes. The laser pickup assembly is bad or the most common failure for DVD and CD players is the spindle motor. This motors bushings fails over time and does not spin the disc at the right speed so the unit times out. You can repair the by purchasing what sony calles the Mech Assembly it comes with new laser and stepper motor as well as the Spindle motor.
Mar 14, 2010 | Sony DVP-NC600 Multi-disc DVD Player
PROTECT
http://www.usersmanualguide.com/
see if theres a manual here
May 04, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Sony DVP-NC600 Multi-disc DVD Player No Disc Error
The only other thing I can suggest, having repaired many Sony CD/DVD players, is to get a can of compressed air and try to blow any dust out from the laser assembly. Since you've already cleaned the lens (the most common problem), you also might have dust down inside the assembly. Try blowing with the air nozzle down inside, around the gap between the lens and the cover surrounding it. Do it from at least a couple of inches away, if the air is too powerful you can damage the wiring inside the assembly.
If this fails to correct the problem, your laser output may have diminished over time and the only repair is to install a new laser assembly. The cost of this part will most likely not be worth it to you since the unit is quite old now.
Mar 02, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
Sony DVP-NC600, CD/DVD Player
Hey llacy2,
There may actually be a number of reasons that this may be occuring, and there are a couple of things that you can try in order to resolve this type of problem.
You may wish to first clean the discs being placed in the DVD tray with a soft cloth. Any kind of dirt, scratches or cracks on the disc may cause the unit to immediately reject it. Once the disc has been cleaned, try to insert it again. If the disc is rejected a second time, you may need to try a different title.
If the problem still persists with more than one disc, the manufacturer has suggested both turning the DVD player off and fully unplugging the player (power cord, other connections and all). You may wish to allow at least 1 full minute before reconnecting the player and AC adaptor, but if the problem isn't resolved after doing so you may need to contact a repair facilty for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 20, 2008 | Sony DVP-NC600 Multi-disc DVD Player
Sony DVP-NC600 Powers down during CD playback
The tray won't open. I took top off and dvd top side holder, but the laser mechanism won't disengage so the tray will open, even with no dvd in it. How do
I reset it. I power on, hit open key, it makes hum noise then goes by to
standby mode.
Jan 06, 2008 | Sony DVP-NC600 Multi-disc DVD Player
Sony DVP-NC600 Multi-disc DVD Player Logo
277 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
