Question about Maytag Atlantis MDE7400AY Electric Dryer
Tensioner pulley spring
Need a schematic for attaching the tensioner pulley spring. It hopefully will show where both ends attach....
We have a Maytag Atlantis electric dryer that we have not been able to find where the serial/model number is at......cant find it anywhere.....
Thanks
  • 20 Answers
Posted on Dec 10, 2008
I have removed the deck from a lt1000 to replace the mandrel. I cannot figure out where the clutch spring connects to get it back together and the schematic on the sears web site does not show how this...
You need to kneel down on the right side of the mower deck, look forward and inside of the right blade pulley. There you will find the tension pulley, with a piece of metal sticking up out of the middle of the pulley. Slide the end of the spring over that post and put the clip in the hole at the end of it to retain the spring. If you have not already retained the cable at the back of the deck, make sure to do so. If you move your hand back from the tension pulley at the back of the deck is a post that the shielded part of the cable is attached to. Make sure when you put the cable into the slot that you bring the collar back to the post and then slide the clip in place.
This should get you going again.
Aug 05, 2011 | Craftsman Garden
Cratftsman Lawnmower; 16.5 horse; 42 inch deck, need assistance replacing armbrake and tension spring #58 on sears schematic; MOwer model number is 917271120-- particularly, where does this spring attach?...
Judging by the diagram the spring mounts under the armbrake, the Bolt (#52) goes through the circular spring. One end of the spring goes into one of the holes near the bolt on the armbrake and the other ( after providing tension by turning the spring ) must attach to a non moving part on the deck to be able to provide the required tension Look for a small turned up piece of metal with a notch in it on the housing.
Hope this helps
May 18, 2011 | Garden
I'm trying to hook up the belt which came loose from the drum. While trying to loop it around the motor pulley, the motor pulley came free and I can feel a spring attached to the motor pulley and the...
the idler pulley keeps tension on the belt itself, and is a complete unit,, it slides into a grove,, and once the belt is correctly installed ,, thats what holds it in place, heres a good reply from another question that may help you with pictures
http://www.wikihow.com/Change-a-Clothes-Dryer-Belt
Aug 03, 2010 | Maytag PYE2300AY Electric Dryer
Can you tell me where I can print instructions for free to help me change my timing belt in a 93 ford festiva
Here are the instructions for removing the timing cover, and for replacing the timing belt. If this is helpful, please click my accept button! Thanks!
Remove accessory drive belts.
  1. Remove water pump pulley to pump hub attaching bolts, then the pulley.
  2. Remove right inner fender panel to gain access to crankshaft pulley.
  3. Remove outer crankshaft pulley attaching bolts, then the outer stiffener/spacer and outer pulley
  4. Remove inner stiffener/spacer, attaching screws, inner pulley and baffle plate.
  5. Remove attaching bolts, then the upper and lower timing covers.
  6. Reverse procedure to install. When installing crankshaft pulley, ensure curved lip on baffle plate and deep recess of inner pulley face outward
  1. Remove timing belt covers as outlined previously.
  2. Remove timing belt tensioner pulley attaching bolt, then the tensioner pulley, spring and spring cover
  3. If reusing old belt, mark direction of rotation on belt to aid installation.
  4. Remove timing belt from crankshaft and camshaft sprockets.
  5. Check crankshaft and camshaft sprockets, tensioner pulley and timing belt for wear or damage. Replace components as necessary.
  6. Align camshaft and crankshaft sprocket timing marks with marks on cylinder head and oil pump housing
  7. Install timing belt. If reusing old belt, ensure belt is installed so that direction of rotation mark made during removal is positioned correctly.
  8. Install spring and spring cover onto tensioner pulley, then install pulley and attaching bolt. Do not tighten bolt at this time.
  9. Install tensioner spring onto anchor, then tighten pulley attaching bolt to torque listed at the end of this section.
  10. Reinstall timing belt covers.
This photo shows timing marks.
Jul 14, 2010 | 1993 Ford Festiva
I have a Maytag performa dryer and the idler pulley came off and i need to know where to attach the spring that it has back to.
Make sure the idler arm with pulley is in the right location and then hook the spring into the idler arm bracket, then look for where the spring might have been attached on the frame of the machine within the limits of a stretched spring.
I will also send you a website that may help you, they have schematics of dryers and it may give you some help.
http://www.partselect.com/ if not then try this one.
http://www.appliancepartspros.com/index.aspx
Good luck,
I hope this helps
Oct 13, 2009 | Maytag Dryers
We have a Maytag Atlantis dryer. Inside the tub
Did you try opening up the back of dryer or the top?
Sep 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I have tension spring that is disconected inside a toro 824 snowb
That spring will attach itself to just about anything available. So put some hand tension on the idler pulley of the tensioner, and make an arc with the end of the spring, and there should a tab or bolt or post that the spring could attach to.
Aug 23, 2009 | Garden
Maytag electric dryer:attached belt as per directions,but is still loose,the pulley seems to not give enough tension
You can verify your belt installation by going to repairclinic.com. Click on the "Repair Help" link at the top of the page, then locate the "Dryer Belt Diagrams" link under Special Features. Refer to Diagram E under the Maytag heading. If you say you have the belt installed correctly, make sure the tension spring is still installed. I hope this helps you.
Jun 27, 2009 | Dryers
Snowblower Treads not turning
Hello, if you go to searspartsdirect.com type in your model number you will be able to find a diagram that will show you where and how the spring attaches
Mar 05, 2009 | Toro Blowers Rake and Vac - Electric...
Maytag dryer
Make sure the belt is properly routed. Often, there is a tensioner that 'adjusts' the belt. It is a wheel that is on a pivot with a spring attached to a fixed point. It may be located anywhere around the drum but is likely near the motor frame. Now, with access to the motor shaft, start the belt over the shaft in the direction of motor spin as much as you can. Try to turn by hand or grab the belt and pull along. ...if it does not work..put the belt over the motor pulley after pulling back on the tensioner. You can use a long screwdriver as a lever. No tensioner? There will be a method of adjusting the placement of the motor. Make sure the motor shaft comes out square to the belt.
Nov 17, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
204 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
