I was adjusting the blue convergence via remote control. The blue cross was way off but did not seem to move no matter how long I pushed the button on the remote, then I heard a short high pitched sound and the tv went black with no sound either. Now I get nothing out of my tv, if you unplug it, when you plug it back in the timer led blinks once quickly and then comes on again for a couple of seconds while you hear some clicking inside the tv. After that I have nothing and the tv will not turn on via the switch or the remote control.
  • 3 more comments
  • maxxwell2 Nov 22, 2008
    This is an Akai pt5492s projection tv.
    I have power to the tv.
    Would a bad STK IC take out the power button on the front. How much is a STK IC
    Wouldn't I still have power and sound if these IC failed.
    Yes Ginco I see your comments but others say I should still have power and sound, and I am having problems because I can only see one comment at a time and can not see the whole thread.
  • 4,889 Answers
Clicking relay problem is not due to the Convergence (STK ICs). A bad STK IC will not keep the set from turning on. I really believe this is the relay switch or some faulty caps. Hard to tell with out physically checking the set. Replacing the PS board can be a sensible idea as well. The board should cost you around 150$. The part number is 1-659-752-11. Good luck!
Sai.
Posted on Nov 24, 2008
    Scholar:
  • 181 Answers
U will have the power and sound if the STK ICs get failed but if with that STK ICs if any other electric component like fuse or capacitor is got faulty it is quite possible that u may not get sound or picture.
but replacing the STK ICs with a proper technician and getting the board checked completely may definately resolve your problem.
and reparing will not be costly it will be negligible and it is worth getting it repaired because as per u stated the problem it can be seen that the tv is in proper condition.just the minute reparing and some small parts needs to be replaced.
Posted on Nov 22, 2008
    Genius:
  • 1,239 Answers
HI IN BACK OF YOU WILL FIND OUT 2 TUNERS THE LEFT TUNER IS THE DISPLAY TUNER .BY ADJUSTING IT YOUR PROBLEM WILL BE SOLVED PLEASE RATE IT..........THANK U...........
  • 4,806 Answers
Sounds like the power realy switch or a capacitor has blown , take the back off the TV and have a look for a "semiconductor" >>>> like these I was adjusting the blue - af5563e.jpg that has blackened, and any capacitors >>>like these f0c3946.jpg which will be swollen
If you heard a "POP" sound after the high pithced sound, this is what i would look for.
regards
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Nov 22, 2008
    sorry thats power "relay" switch
    regards
  • Lee Hodgson
    Lee Hodgson Nov 24, 2008
    you will not get power or sound if a relay switch has blown
  • Lee Hodgson
    It is not easy to fix. I don't think it is worth repairing because it will cost more than the price of a new set.
    The "clicking sound" is a symptom of
    crashing power supplies, protection and power management systems gone
    out of control. There could be several ailments with the set.
    Sergeant:
  • 276 Answers
Stk will cost not more than 30 dollars.fixing it through technician will be charged as per the technician service charge
  • smarttech Nov 22, 2008
    yes even if the stk ic is faulty u will still get power and sound.stk ic related only to the convergence part.
    Genius:
  • 1,550 Answers
STK ics will cost you around $20 -30
You can get from the link below
Buy IC
    President:
  • 1,952 Answers
The convergence ICs have failed. There are two of them and they must be removed (un-soldered) and replaced. Sometimes there are a couple of burnt resistors that need to be replaced, also.
It is not a job for the faint hearted. Only if you have advanced soldering skills should you attempt it on your own. The ICs, called STK392s cost around $10 to $50 each depending on where you purchase them.
If you have a repair shop do the job it will cost around $400 or so.
  • mohammed marika thambi
    mohammed marika thambi Nov 22, 2008
    yup u will get both power and sound..but picture will be unaligned
    have u seen mine?
  • 19,396 Answers
That is probably because one of the two convergence ICs had blown, the pico fuses on convergence board must be tested.
  • 7 more comments
  • Ginko
    Ginko Nov 22, 2008
    Test back the two stk ICs onconvergence board, or have them tested by a technician.
    When the service convergence procedure does not work, you need to test the pico fuses on convergence board for continuity, and eventually replace the defective STK IC.
  • Ginko
    Ginko Nov 22, 2008
    I will explain the situation:
    On your convergence board you find two ICs, they are called STKs or generally convergence ICS, they are power amps ICs that regulate TV's convergence.
    You probably started to have problems with convergence because one or both ICs were starting to fail.
    The convergence setup procedure did not work, because one or both the ICs were indeed faulty.
    Now the TV is not starting at all because the IC had blown.
    You test the ICs by checking for continuity the pico fuses at the base of the ICs, on convergence board.
    To replace the STKs you need to do a precision soldering , using good tools and thermal compound.
    Replacing the whole convergence board is easier, but it is still a work that should be done by a technician.
    If you want to call a technician you can use the number listed on the user manual.
    If you want to do it yourself, or buy parts yourself, check on this website.
  • Ginko
    Ginko Nov 22, 2008
    What does it mean "take out the power button on the front"?
    When the convergence board is faulty because an IC has blown, the TV goes in protected mode, that means that the TV stays in standby and do not start when you press the button.
    I am not sure you will be able to see my comments , as you refused my previous solution.
    The STK ICs cost a couple of dollars, the convergence board costs from $60 to $80 I think, you find exact quotes on the website I gave you, let me know if you can still see my comments.
    Thanks.
  • Ginko
    Ginko Nov 22, 2008
    Leave the TV unplugged overnight, this will drain power completely from the TV circuits.
    If it does not startup in the morning you will need a technician having a look at the TV and probably replacing convergence ICs or whole convergence board.
    Here is the STK for your TV, you have two of them on convergence board, the board must be ordered from akai.
    Here is a broad explanation on how to do the job.
  • Ginko
    Ginko Nov 22, 2008
    I answered ten times or so, no if the convergence ICs fail , you get TV in standby , no sound, and TV safety protection switch clicking with tv not starting when you press power switch.
    Can you read my comment?
    Thanks.
  • Ginko
    Ginko Nov 22, 2008
    Can you read my comments?
  • Ginko
    Ginko Nov 22, 2008
  • Ginko
    Ginko Nov 22, 2008
  • Ginko
    Ginko Nov 22, 2008
    Others do not have a clue , on Fixya you have both users like you and real technicians, the others know probably less than you and are just guessing.
    Lets go back to the problem:
    What you are experiencing is nortmal, what you heard clicking is the protection circuit switch turning off TV to prevent further damage, as it had detected a fault.
    Since you started having convergence problems, and the convergence procedure failed, it is likely a convergence problem.
    The most common convergence problem is the convergence ICs blowing..
    Replacing convergence ICs is not a job for beginners , you need a technician.
    If you have the user manual call Akai and ask a quote for the repair, and also ask if you can get a warranty extension.
    A repair at a local repairer will be around $200, at least that is the average cost in UK.
    The ICs cost $6.99.
    Things you can do and must do:
    Leave TV power cord (and all other cables ) unplugged overnight. As I explained this is called hard reset will fix the problem if you are very lucky and the ICs are not faulty.
    Call AKAI and ask: repair cost for convergence fail (describe situation), and eventual conditions and availability of warranty extension, if available this will be cheaper than repair.
    Call also a local technician and ask a quote for repair.
    If you do not care about the risk of damaging your TV, you can buy the ICs and do it yourself, if you are not confident with this kind of repair there is a good chance that you cause more damage to the TV.
    Let me know.
    Brigadier General:
  • 3,614 Answers
Have you trying plugging it into different outlet...?
check all the possible loose connection..
if all of this was corrected, you will need someone to check the possible faulty or problem inside the tv.
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
Picture in 3d without the 3d glasses
your convergence settings are moved and they need to be adjusted and if you adjust and still have the problem then its the problem of convergence STK ICS and they need to be replaced.
for adjusting the convergence please click this link this will help you how to adjust the red, blue and green settings in your tv.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
for replacing the convergence STKics just click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
feel free for further assistance.
thanks.
Oct 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence Adjust
It means probably one of the two convergence ICs has blown
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Multi point convergence
In the multi-point adjustment grid use the exit/status button on the remote to lock onto the cross-hair that you want to adjust and again exit/status button to continue back to moving the cross-hair around to another location.
Bill
Dec 01, 2007 | Philips 43P8341 43" Rear Projection...
Convergence
Replaced convergance power packs (2) stk392-110 check all 2watt resistor the packs, to enter the convergance alinment mode on the set. Using the remote control press and release the sleep timer button when sleep timer displays timer equals zero immediately press the display and V. status buttons at the same time.  If done quickly enough the service menu will appear once entered the careful not to does disturb or change any other settings press the number seven to enter the convergence alignment mode a full crosshair pattern will appear in this alignment mode you can adjust the blue and the red to line them on the green using the select and the number pad you can move to the next crosshair to align the boot to the green and then the red to the green when done pressing the muting button on the remote control will save your changes will take a little while to figure this out as you work with.  If you make an unwanted error pressing exit without hitting the muting button will restore your convergence to its previous  setting.  If you're green is off after entering the service mode press the number six on your remote control in this setting will be able to adjust the green only once that is done us the muting button.  Then enter button seven if need be to adjust the blue and the red.  Remember no changes have been stored until the muting button is pushed open this helps.
Oct 14, 2007 | JVC AV-48WP30 48" Rear Projection...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
