Question about Pioneer Audio Players & Recorders
Pioneer vsx-602s receiver has no speaker or headphone output from radio or any other source. What can I check next? Where can I get it checked out and/or repaired? Thanks
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Pioneer vsx-d902s
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
Posted on Nov 08, 2008
SOURCE: Pioneer VSX-D608 Optical connection
Do you have the original remote for the receiver? You need the remote to set up the optical settings according to the manual there is a fair bit of things to do to set it up reply if you do have the remote then I will post up word for word on how to change the settings but without the remote you basically cant do much with it sorry
hope this helps
Posted on Sep 21, 2008
SOURCE: Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
Posted on Oct 15, 2008
  • 30 Answers
SOURCE: pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Posted on Apr 02, 2009
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
No sound
On the bottom row of buttons next to the headphone jack, the button on the far right is labelled speakers. Try pressing that button to turn the speaker outputs back on.
Nov 24, 2011 | Pioneer Elite VSX-91TXH
I need to connect my tv to my pioneer vsx-d711 so the sound comes out of the speakers i have hooked up to it
check if your TV design a digial output, like optical or coaxial output, digital source it better
Mar 28, 2011 | Audio Players & Recorders
Pioneer VSX-01 TXH receiver turns off
Sounds like the speaker circuit is overloading or the receiver is overheating.
Check to make sure all speakers are in phase. Pos to Pos. Neg to Neg.
Make sure receiver has plenty of cooling room.
Hope this helps.
Apr 16, 2010 | Pioneer EliteĀ® VSX-01TXH 7.1 Channels...
Hi there. Need some help. I love my pioneer
Get an RCA-to-whatever-size-the-headphone-output-on-the-IPOD-is adapter and jack it into any available aux or line level input.
Feb 02, 2010 | Pioneer VSX-454 Receiver
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
My speakers arn't working with my new t.v.
Any sound from other sources ie. a CD/DVD unit, Tuner etc.? If so then the issue is the signal path fron the TV to receiver, What cableing do you have from TV audio output? Try standard analog 2 channel to the receiver tv in, be sure you select TV on the receiver mode,also check the TV sound menu options, some require that you disable TV speakers and use the audio line-out option fixed or variable.
Feb 01, 2009 | Pioneer VSX-815-K Receiver
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
Pioneer Audio/video Multi-channel receiver Mod#VSX-D710S
Have you tried a 2nd source like the CD input or AUX input?
Have you tried the headphones..same static?
If nothing works then the output amp is broken. There could be internal fuses but only open a stereo when the power is DISCONNECTED. Then check for fuses
Feb 01, 2008 | Audio Players & Recorders
253 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
