Question about Goodman GMS80453ANA Open Flame Mid-Size Heater
Blower speed too fast
Goodman GMS80453ANBC. I think the blower is on med or high. Need low speed.
  • 56 Answers
The furnace should be a 3 or 4 speed motor in it. On the circuit board there are places maked heat and cool. If you are looking for low the red wire should be plugged into the heat designation. make sure unit is unplugged before changing
Posted on Feb 13, 2009
How do I wire blower moter
Black- high speed Red- low speed Blue- med. high Yellow- med. low White- neutral Usually black on "cool" terminal on board, red on "heat" terminal on board, and remaining 2 on the "park" terminals on board. White goes to the neutral terminals. Hope this helps!
Nov 14, 2012 | Goodman GMS90703BXA Heater
Blower MoterElectrialDiagram for a 40,000Furnaces to a Ton1/2 Air conditioner
You will put the red wire from the blower on the terminal marked "heat" on the control board. Black= high speed Red= low speed Yellow/Blue = med low/ med high Hope this helps!
How can I make the ac quieter inside the house?
If you have hard ducts, you can use some flex duct between the supply plenum and the hard ducts as a way to quiet the noise down.
May 10, 2017 | Goodman Heating & Cooling
2008 Honda Odyssey AC fan works on low and med speeds but no high speed blower
There should be a high speed blower relay that bypasses the resistor for slower speeds.
Check with an auto parts store or the dealer.
Jun 23, 2012 | 2008 Honda Odyssey EX-L
1996 astro chevy van heater use to work on low and med but wont work at all now.
The blower resistor has gone bad which is why you lost blower speeds.This may have been caused by the blower motor drawing too much power. At this point I would verify that no fuses burned out and then check the pigtail plugs going to the resistor and blower motor to make sure the connectors and connections are not melted or wiring is frayed. These connectors are located in the engine compartment on the passenger side. After checking this and if everything appears ok then the blower motor itself has probably gone bad and needs replaced. I would also replace the blower motor resistor as well. If the connectors appear damaged replace or repair as needed .
Jan 10, 2011 | 1995 Chevrolet Astro
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
Jan 12, 2010 | Desa International Blower Glow Warm Wall...
How to tell blower speed on Goodman PGB030050 REV A
one way is to take an amp draw of the motor if you have an ampmeter otherwise
most systems will have the wires color coded black is high
blue is med high
red is med low
yellow is low
and white is nuetral
usually there is connectorson the board labeled "cool" "heat" and "park" park are the unused leads just swap wires
if there is no terminals look to see which wire is wirenutted and switch t with one of the unused ones
Jul 28, 2009 | Goodman CLQ36AR49 Air Conditioner
Coleman outdoor furnace/AC blower speed too fast
You are right slow for heat and fast for A/C. Here are the blower speeds black is high blue is med. and red is low if you have orange it would be med low. Look on the control board and see what color wire is connected to heat and let me know if you have something other then control board. You can take the wire that is on park and swap them around. ken
Jan 11, 2009 | Heating & Cooling
My blower fan came off the motor shaft.
THE BLOWER MOTOR HAS 6-WIRES ....2--CAPICATOR (BROWN- BROWN WHITE STRIPE)3- SPEEDS BLACK-HI-SPEED--BLUE--MED......RED--LOW SPEED OR HEAT AND THE LAST ONE TO COMMOM.
Nov 23, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
268 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
