Question about Canon Optura 10 Mini DV Digital Camcorder
Sound is ok, but do not record images.
Blue vertical lines appear on the screen when I turn it on to camera to record. When I press record I can't see nothing on the screen but vertical lines, and can't record images, but the sound do records. Thanks
I have had the same problem since I purchased mine 4 years ago and it has been repaired 3x and is in the shop for a 4th. I had the extended warranty and Futureshop refuses to acknowledge that it is a Lemon and should be replaced as they don't consider resoldering wires as a "repair". My unit has been in the service center a total of 12 weeks over the 4 years. The service center recommends Sony Camcorders and the Claim center said they get few Sony camcorders so I would say the Canon problem is an issue that is common. Sorry to say. Mike
Posted on Mar 22, 2007
Recorded Video Image Problem
Without knowing the make and model of your camcorder, we cannot offer advice.
Aug 22, 2017 | Video Cameras
When turned on, my Olympus 700 Stylus digital camera shows a thin green vertical line on the right side of the viewfinder--7/16 of an inch to the left of the right edge of the viewing area. Part of this...
this is a problem with your CCD and not any software fault
and so best solution wil be to get this serviced by authorized service center
Oct 05, 2008 | Cameras
Images not recording
I have a sony 14E and suddenly it stopped playing and recording. With vertical lines on the screen I knew to clean the heads. No effect on the recording/playing malfunction.
However I persevered and it seems to have worked in it is now recording and playing back. The steps I suggest, with PERSEVERANCE, are :
1. Clean the heads (I did it 3 times in all, with about 1 hour between each session);
2. Leave the camera open (tape section) for about 2 hours and put the camera (with or without tape) in a warm place. (I also had condensation messages).
3. Once it is warm put in a recorded tape and attempt to view it. At first I had "dirty" vertical lines for a few seconds but it cleared and played normally.
4. If Step 3 still does not work repeat 1 and 2. As I said PERSEVERE.
If Step 3 works then try to record. It should work hopefully. If not, repeat 1 and 2 (shortening the "Warm Up" time).
Good luck. I hope mine continues to work OK now. It is to do with dirty heads and coldness I think.
Jan 03, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Olympus sp510uz no sound on video
From SP510 camera switched off:
1. Turn dial on top plate to movie mode (selections from the menu screen apply to the mode the camera is set in);
2. Switch on SP510 power;
3. Press "MENU" button on back plate;
4. Select "Camera Menu" from screen if not already on it, using navigation buttons on back plate
5. Scroll down yellow "Camera menu" tabs to microphone picture (below "Digital Zoom"), which may be showing "off". Select OK and toggle yellow tab from "off" to "on", then press OK button.
6. Microphone tab should now show "on".
7. Return to main menu (press MENU button).
8. Return to image screen (press MENU button).
9. Test to see if video now records sound.
10. If is still doesn't record sound, try "reset" from video menu screen (this will reset the movie mode to factory settings, including microphone on).
Dec 21, 2008 | Olympus SP-510 UZ Digital Camera
Vertical lines on LCD screen after taking shot.
put the camera in the hearse and take to cemetery and then go buy a new one , you cant take all the money you made with you.
Oct 19, 2008 | Kodak EasyShare Z612 Digital Camera
Lines on screen
is it when u guys take the pic or after the pic taken ?
if the lines appear when u are taking pics, press the DISP/BACK button then the vertical lines will gone :D
if the lines appear on the pics then i dont know how to.
Sep 16, 2008 | Fuji FinePix Z10fd Digital Camera
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Image being displayed is all colored vertical lines
I had this problem a lot on Labtops. The problem is that it has been unliquifed in the screen. This means that the screen has been damaged or has got really hot. Also its has been on for along time. LCDs go bad real quick and can be a hassle when you need the infomation in the thing and have no display. When I had this problem on my labtop, I used the external bay to use another monitor so I can work on it. So I say that nothing can be done to fix it. The only way to see your stuff on there is to use the video out on the recorder and try to check your stuff. That multicolor lines you saw is becoming major right now in LCD displays. I hope this solves your problem.
Nov 13, 2006 | JVC GR-D22U Camcorder
Does the L410 do audio recording?
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
Note:
You must have at least one photo saved to record a sound memo.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Why are there vertical lines or bars on the monitor screen when I record a movie?
Recording a movie of a subject that is brightly lit by the sun or some other very bright light source can cause vertical lines or bars to appear in the image during playback. This is due to a CCD phenomenon called "smearing." Note that lines or bars appear in movie images only, but not in snapshots. Smearing does not indicate malfunction of the camera.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Canon Optura 10 Mini DV Digital Camcorder Logo
129 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
