Question about Compaq A1000 InkJet Printer
Compaq A100 All-In-One is not working with Windows Vista...HELP
My Compaq A1000 InkJet Printer used to work with my old computer operating system (Windows XP) now I've upgraded to Windows Vista and from some reason my printer is not working. I check the HP website and there is no drives from Vista listed. How can I get my printer to work. Or, is there a capatible printer driver I can use. PLEASE HELP
    Problem Solver:
  • 4 Answers
If it came with a disk the you need that to install the drivers for ur printer. if ont go to http://www.nodevice.com/driver/A1000_All-In-One/get22235.html then go to the bottom wher it says enter the captcha (the picture with words in it) and then download it to your desktop. then plug it in. then once windows starts to search for drivers cancel that then go to start menue. then right click on computer. then click on manage. then enter user cridentials f needed then go to system tools. then at the bottom ther is a device manager. open that. the printer shuld be highlited with a yellow triangle and an exclimation point. right click on that and clicl on update drivers. then it will say let windows install for you or browse my computer for my software. then it will say enter location of driver software. click browse on the right side of that bar and navigate to where you saved the drivers from the site above. then you find the software then doubble click on it. then windows sill install it and it should work fine
Posted on Feb 11, 2010
Is my printer compatible with windows 7?
yes, can be.:D just follow these steps:
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Oct 30, 2010 | Compaq Inkjet Ij300 Printer
Where can i get a windows7 compatible printer software?
Maybe, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))julyallan01_31.jpg
Oct 25, 2010 | Compaq Inkjet IJ600 Printer
Is the Compaq A1000 compatible with Windows Vista
No, sorry, HP does not supply a Vista driver. Refer to Compaq A1000 Support
Click on Software & Driver Downloads for available drivers.
Thanks for using Fixya, just the same.
Nov 22, 2009 | Compaq A1000 InkJet Printer
Compaq A1000 printer needs to be installed with my windows vista
As it stands right now it does not look like HP (Compaq) are not going to update there drivers to support Vista. Sorry for the bad new.
Nov 03, 2009 | Compaq A1000 InkJet Printer
Need the manual
Here is a link to the User Guide in PDF format:
Compaq A1000 User Guide
This is a rather large file (26MB) so be patient. Once opened use the small floppy icon and save a copy to your computer for future use.
Thanks for using Fixya.
May 14, 2009 | Compaq A1000 InkJet Printer
HP OJ 5610 Drivers-? Can not install printer.
In this case, there's no mystery as to the cause of the problem. You will be unable to use this printer with your operating system because there are no existing print drivers that work with 64 bit Vista. Your printer will work with Windows 98, Windows 2000, and Windows XP, but not with Vista at all.
You have only two options...use a different HP printer that will work with Vista, or get a PC that has one of the supported operating systems on it and connect your current printer to that PC.
Sorry. I know this isn't the answer you were looking for, but that's the best I can do until the proper drivers become available.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Compaqa3000 cant install
HP does not currently have a driver release for the Compaq A3000 All-In-One that is compatible with the Windows Vista operating system. You can attempt to find an alternate driver that works but it may cause system instability, if it works at all. I recommend upgrading to a printer with a Vista-compatible driver available because it is the most stable solution.
Jul 05, 2008 | Compaq A3000 All-In-One InkJet Printer
Compaq A1000 problem
Go into the control panel go to system properties then device manager then disable the fax modem card in the list and if its an onboard device then disable it from the BIOS. you dont need a faxmodem card for your internet as its required for dialup connection.
May 18, 2008 | Compaq A1000 InkJet Printer
Lexmark won't work with vista
Yes works with Vista but you will need to use Vista driver not XP
Rate this solution then Download here
Delete old install before reinstalling!!!!
Release Notes Attention: To prevent issues during the installation, please uninstall all previous versions of this driver prior to installing this web package. File Information File Name: cjr1200EN.exe null.gif Version: 1.0.11.3 null.gif Released On: MAR 05 2007 00:00:00 null.gif File Size: 42452912 KB null.gif Products: Lexmark X1240, Lexmark X1250, Lexmark X1270, Lexmark X1280, Lexmark X1290 null.gif Languages: null.gif Operating Systems: Windows Vista null.gif Application: n/a null.gif Owner Name: Lexmark null.gif Data Stream: Lexmark Host Based Solution, Lexmark Scan and Copy Control null.gif Security: null.gif Install Instructions:
Dec 25, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Compaq A1000 InkJet Printer Logo
203 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
