I am currently driving an 86 Z28 carbie 305 with 5 speed gearbox. I also have a 1990 fuel injected V8 with a T700 auto in the shed, it has the computer and all sensors etc but no wiring. What am I up against if I am going to fit this engine into the 86, I would like to keep the 5 speed but is the computer wired to suit the auto?
Any help from anyone who has the experience with this sort of engine swap would be greatly appreciated.
Cheers, Craig
You can get an "engin swap wiring harness" from jegs or summitt that would require a little extra work on the wiring on the inside of the vehicle, however if you have the original wiring harness for the 90 engine, there is a plug on the inside of the right(pass) fender of the camaro that connects the internal wiring to the external. (plus the fuse block connector under the hood on the firewall on the driver's side) as far as the trans. i did the same thing with mine and kept the 5 sp, the only real problem is that i don't have back up lights.
Try painless.com for a wiring harness.
