Question about Linksys Wireless-G WRT54GS Router (e125894)
Linksys wrt54gs won't work
I can't get my linksys wrt54gs to work it has been doing fine but went off last nite called cable because modem lights were off they are on now and i am pluged up directly to modem
  • harleygranny Nov 23, 2008
    i found what was wrong already it was not linksys it was the modem i restarted it the cable people didn't know what he was doing thanks
    President:
  • 2,992 Answers
Your router might need a restart to begin communicating with the modem again. Remove power from the router, wait a few seconds, then turn the power back on.
Posted on Nov 22, 2008
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
Switched from DSL modem to Cable modem. Linksys
If you had your linksys router controlling the DSL connection, it was most likely a PPPoe connection requiring a username and password. Most cable companies have dynamic IP address and do not require a username or password.
Open your internet browser, IE, Firefox etc and go to 192.168.1.1 >
Enter your router username and password, typically admin and admin
In the setup tab, change your connection FROM whatever is listed there and make sure it is Autumatic DHCP Save your settings, and restart the router.
You should be fine.
Oct 27, 2009 | Linksys Wireless-G WRT54GS Router...
I need instructions for a Linksys Wireless G router to work
Call your internet provider they will walk you thru the process.
Jun 18, 2009 | Linksys Wireless-G WRT54GS Router...
The port of Linksys Wireless-G WRT54GS Router Linksys Wireless-G WRT54GS Router
What do you want to know about the ports? The one separated from the other ports is the Internet port. that is where you're going to connect the cable from your modem. The other four are the ethernet port where you will connect the computers.
Jan 22, 2009 | Linksys Wireless-G WRT54GS Router...
Cannot connect to internet Model WRT54GS
Hi
I would like to know who is your internet service provider and would like to check if the router is configured with your ISP modem.
To configure for different ISPs here is the link
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US/Layout&cid=1166859761879&pagename=Linksys/Common/VisitorWrapper&lid=6187977881B11
The links are there for setting up with DSL as well as cable modem. Do let me know if its working or not.
Thank you
Rakesh
Jan 06, 2009 | Linksys Wireless-G Broadband Router
Internet connection between linksys router
May be your router internet settings has been wrong. you must reset the router settings by clicking the router reset button. Pls locate the button and then put the internet cable into router internet port.
Jan 03, 2009 | Linksys Wireless-G WRT54GS Router...
Help
You do not need the manual or CD
1. Turn off both the linksys and your modem
2. Turn on your and wait for the usual lights to turn solid
3. Turn on the Linksys and wait 30 secs
4. Press the button on the front to the left. It does not look like a button but flashes while it is finding an ip address
5. now connect with an Ethernet Network Cable and make sure the internet is working
6. Next Setup the Wireless Encryption, if you don't know how to do this, post and I will help
7. Disconnect the cable and Connect Wirelessly
If you have limited connectivity then next try this: http://www.howtofixanything.co.uk/howto-269.html
Jan 02, 2009 | Linksys Wireless-G WRT54GS Router...
WRT54GS
Make sure the cables are in the right places, then go into setup, and make the IP of the router 192.168.2.1. I seems to be a ip address conflict
Aug 25, 2008 | Linksys Wireless-G WRT54G Router...
Linksys Wireless model # WRT54GS
It sounds like the router went bad and your need to get a new one
Mar 05, 2008 | Linksys Wireless-G WRT54GS Router...
WRT54gs' internet link wont come up
Here's a couple of places to get started:-
1. If you're on the internal network, try logging into the router's admin page, and iff you can see link to the cable modem / DSL line "Internet Interface". Try Refreshing DHCP on that interface.
If it's not looking great, or it's not serving out DHCP, do a quick powercycle on the LinkSys and see if that clears it (I would guest you've tried this though!)
2. Check your cable modem / DSL line box and ensure that all its lights are as normal (Without Make / Model etc I can't help you in detail there.
3. Try powering off your cable modem / DSL box and then your link sys. Wait 10 minutes (Yes, that long, there are reasons for that involving the upstream network). Powerup you Cable Modem / Link Sys box, once that looks healthy (Maybe 2 minutes to boot with some models) power up your LinkSys and see how things look then.
If you're still not having luck, unplug the power from the LinkSys again. Press and hold the "Reset" button, keep it pressed, and reapply power. Count to 10 before letting go. Wait a second or two, then press and hold the rest button again for another 10 secs. See how it looks then.
4. If all of the above doesn't help, call up your ISP and ask them to run a diagnostic on your Cable Modem / DSL Modem.
5. If you CAN get to the web page on your LinkSys, and you KNOW the cables are good then you should try putting the original firmware back and see how things go then.
If you're still having issues after all of the above I'd suspect you have faulty hardware.
Nov 16, 2007 | Linksys WRT54GS Wireless Broadband Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
96 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
