Question about Canon PIXMA MP830 All-In-One InkJet Printer
How to configure recto verso document printing on Pixma IP4600?
Cannot find this option  in menus - printer is sold as automatic recto verso!
PS your product list did NOT include the IP4600 so I selected other to enable submit
  • 3 more comments
  • hthuy Nov 22, 2008
    Printer is Canon Pixma IP4600
    recto verso means printing two pages on 1 sheet, front and back.
    The Canon Pixma IP4600 is sold ad being able to do this, even automatically.
    I cannot find this option in the print setup dialog boxes (on my Mac - printer is sold as PC and Mac compatible!)
    Canon support is ... dead!
    I installed the Mac drivers available as per the printer setup CD v M1.0 which came with the printer
    to micromaster:
    the driver you suggest is an easyphoto printer driver - I am talking about double-sided document printing on A4 size paper
    to leecom72
    this link does not provide me with any new drivers nor manuals nor other . The intial setup CD includes al that.
  • 4,806 Answers
Go here to the canon USA support site to get the drivers, software and user manuals to rectify your problem:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=17105
kind regards
Posted on Nov 22, 2008
  • 10,515 Answers
Assuming this printer does not have built-in 2-sided capability: Click FILE - PRINT and in the Print box change All Pages in Range to Odd Pages. Print your document and then reload the printed pages so the blank side will be printed on (keep them in the same order!) and print, setting the Print box to Even Pages.
  • Canon Master
  • 19,396 Answers
How can you configure recto verso on a printer that does not have recto verso settings?
Your printer has automatic double side printing. That means that it will automatically print on both sides to save paper unless " automatic double side printing" is disabled. You cannot set recto verso on this printer, it is automatic.
If you need more settings I suggest buying a professional color laser printer.
  • Ginko
    Ginko Nov 22, 2008
    Before you eventually refuse my solution, and cut down communication, I wanted to say that I went through printer specs before telling you this, I am not just guessing. You cannot set recto and verso, or collate, you just print and decide if you want simple single side, or automatic double side. That is all you can do on this printer.
    Here is my previous comment;
    Your
  • 488 Answers
  • Lalit Varadpande
    Lalit Varadpande Nov 22, 2008
    it says its available only for windows
    "Two Sided Printing:
    Automatically selectable using plain paper in A4, B5, A5, Letter & 13 x 18cm sizes (Windows only) ; Automatically selectable using plain paper in A4, B5, A5, Letter & 13 x 18cm sizes (Windows only); "
  • Lalit Varadpande
    the feature u want is not available for Mac and its only for Windows...
    Genius:
  • 1,239 Answers
HI SIR I CANNOT UNDERSTAND YOUR PROBLEM CLEARLY.IF YOU EXPLAIN IT CLEARLY,IT WILL BE MORE USEFULL TO ME TO GIVE CORRECT SOLUTION
    Brigadier General:
  • Canon Master
  • 3,614 Answers
May i know the exact model maker of the unit.
  • micromaster
    micromaster Nov 22, 2008
    get the diver HERE and install it into your PC
  • micromaster
    • Confirm that the cable is connected and the printer is powered on before continuing.
    • Do not use paper sizes smaller than 5" x 7" when using the 'Automatic Duplex Printing' function.
    • Due to OS limitations, multiple copies cannot be printed when 'Automatic Duplex Printing' is selected.
    1. To open the Print dialog, open the file to print, and select 'Print' from the File menu.
    2. In the Printer pop-up menu, select the printer you are using.
    3. In the third pop-up menu from the top, select Duplex Printing & Margin.
    4. Check 'Automatic Duplex Printing'.
    5. Select the proper options for the following:
    (5-1) Print Area:
    In duplex printing, the printable area of the top of the paper is
    smaller than normal printing by 2 mm. To keep the entire print data
    within the printable area for printing, select 'Use reduced printing'.
    To print in regular size, select 'Use normal-size printing'.
    (5-2) Stapling side: Select one of the following for the location of the staple:
    • Long-side stapling (Left)
    • Long-side stapling (Right)
    • Short-side stapling (Top)
    • Short-side stapling (Bottom)
    (5-3) Margin for stapling: Specify the margin between 0 and 30 mm.
    6. Click 'Print' to perform printing. Note: After printing on the first
    side of the paper, the printer will stop printing temporarily to allow
    the ink to dry. Do not touch the printed surface.
    7. Settings for duplex printing are completed.
    President:
  • 1,952 Answers
Have u seen in manual?
My printer doesn't want to phtocopy in recto/verso
A4 is 81/2 x 11 and A3 is 11x17. what is recto/verso????
Feb 05, 2013 | Konica Minolta "Minolta Bizhub 363 Copier,...
Tip
How to print a page recto verso
i would like to know if i can print a page recto verso with my cx3900 please if it's possible tell me how thanks
on Jul 08, 2011 | Epson STYLUS CX3900 All-In-One InkJet...
I have an Apple Mac and cannot get the iP4600 printer to use the rear paper feed; nor can I find an updated printer driver (I bought the printer only a few months ago)
open the print dialog window,have a look around the options there, with the printer selected you should get some options that will turn the feature on.
Aug 11, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
I want to print on a CD using a Canon Pixma iP4600
hi,
1. to print on a cd, there is a (cd sticker paper) available in the market, buy it and feed it in your printer...
2. to print on a cd, you should have special software such as... Nero Burn version 5.0/5.5/6.0/6.5/7.0,
this is a cd burning software, in this software you will find sticker designing option, where you can
select images or text to design the cd for printing..
Jun 21, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon pixma ip4600 black ink problem
The PGI-220 is the larger ink tank and is filled with standard black ink. The PGI-221 black cartridge is the photo black. There is no way to force the printer to use the photo black cartridge (skinny one) to print documents. The photo black cartridge is only used if you print a photo. I own a Cartridge World ink refilling shop and I can't refill these cartridges yet. There is no way to reset the ink level chip without a resetter and any replacement chips you find on the internet are technically violating patent law.
Jan 28, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Printing recto verso
On your computer, click mouse on windows icon in lower left corner of screen. When the menu appears, left click on 'printers'. Go to the icon representing the Xerox, and right click mouse. from the drop-down list, chose 'properties' at the bottom. The 'properties' window should appear. Under the ''general' tab, it should show 'yes' for double sided prints. Go to the 'accessories' tab and left click mouse. A list of installed accessories should appear. See if there is a 'duplexer' accessory available. If it is, left click on the duplexer display and add it to the Xerox. Left click mouse on "apply" tab, then left click on the "OK' tab. Exit out of 'printers' and test.
Jul 05, 2008 | Xerox WorkCentre M123 Copier
Canon PIXMA MP830 All-In-One InkJet Printer Logo
836 people viewed this question
old marine
old marine
