Eo2 lockout problem with my weil McLain ultra 105 series 2 boiler. I believe it is the flame sensor as I have no problem with the ignitor. Any suggestions? The boiler goes into lockout periodically and has to be reset.
4 Suggested Answers
SOURCE: My oil boiler is a
The actual final solution was to replace the fuel valve/solenoid following which the boiler has run without failure.
The conclusion was that the fuel valve solenoid was ok when cold but when heated up had some sort of electrical breakdown in its coils, causing the fuel valve to fluctuate until the boiler locked out.
Posted on Oct 17, 2008
  • 108 Answers
SOURCE: I have a weil-mclain CGA-4-SPDN
You need to replace the Thermocouple. (pilot safety device) It would be best to call a Technician about this.
Posted on Oct 22, 2008
  • 833 Answers
SOURCE: How to replace collapsed fire
Your heating supply store will have a replacement unit.  I do suggest you get a pro to do this, however.  Your burner should be tuned and this is not a job for an amateur.
Posted on Nov 15, 2008
I have a mclain 68 boiler... I have no power going from boiler to thermostat. what can that be?
Could be a disconnected wire or failure of the thermostat power supply.
Oct 23, 2016 | Heating & Cooling
Boiler working but no hot water
Pump circulating heated water to the tank? Set the temp adjustment on the tank?
Sep 02, 2014 | Weil-McLain Ultra Plus 40 Indirect Fired...
Green light keeps blinking
If it blinks like a heartbeat, it's normal. If there's a series of blinks and a pause you need to contact the manufacturer to read the code.
Apr 16, 2014 | Weil-McLain Heating & Cooling
Light the pilot light on weil mclain gas boiler
Joanne If there is a standing pilot on the boiler. Put the gas valve to the pilot setting and push in on the valve while holding a long match or BBQ lighter @ the pilot assembly that is behind the small access port at the top of the gas train assembly. Dont hold the pilot knob doun without having a flane @ the gas outlet of the pilot assembly or gas will build up and could blow out of the port and hold the gas valve in for about a minute or two and let it go it should stay light when you let it go .If it does not sta lit and it IS a standing pilot there- is a thermo-coupling that may be bad If the pilot does not stay lit.
If there is an electronic ignition rather than a standing pilot then you do not need to light it will light itself if the electronic ignition is bad or if the flame sensor is dirty. If you remove the pilot assembly from the gas train and clean the flame sensor rod with a piece of .0000 steel wool it could help. If not you may want to call a licensed pipe-pitter ( OR plumber depending where you live and the local codes).
If you don't thing you could do it yourself then call a licensed pipi-fitter or plumber. (Gas only has to leak once for there to be a problem so please do call someone licensed if you don't think you could do it your self.), http://www.weil-mclain.com/en/weil-mclain/products-services/
Here is a link to the manufacturer you should be ale to fing your equipment and the install instructions, if you look around .You can download a PDF and print it
Good luck and stay warm
Feb 08, 2014 | Weil-McLain CGa-25-SPDN, NG, Gas Fired...
Have a water leak inside boiler keeps putting pilot light out
Not good at all. Check for a fill level probe/float/sensor that may be acting up causing the unit to over fill, or you may be looking at buying a new boiler.
Feb 18, 2013 | Weil-McLain CGa-25-SPDN, NG, Gas Fired...
Make : Weil-McLain Model : CG-5-SPDN Series 12 I have the above mentioned boiler which is located on the 1st level of a three story one family house, the area where the boiler is located is insulated.
You don't have an optimum distribution of steam in your house. Try closing a little bit the valves supplying the heaters in the lower floors. Close a little bit more until you get the desired balance.
Nov 06, 2012 | Heating & Cooling
Lockout light flashing for 1/2 sec.
Press down and hold the reset button. You may need to bleed the oil line once you get oil in the tank.
Feb 23, 2010 | Honeywell Heating & Cooling
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
