Question about Cameras
My casio 8.1 megapix model EX Z9 Problem The lens won't come out( did it auto.). it says "reentry power on" or "lens error" on the screen I did drop it. Do you think I have a ruined camera not worth fixing ? Can you tell me what to do to fix this myself?
  • 5 more comments
  • MarcyRN Nov 22, 2008
    Thanks ,
    I tried this and it didn't work. Any other ideas are appreciated. Marcy
    welcomege,
    I wish I had the tool to take it apart. I will try to buy a teeny screw driver and then try it asap.
    My last response was to the person who told me to take and leave out the battery and then put it back and tap the camera. That is the one I tried and it didn't work.
    Thanks Marcy
    any ideas for me that don't require taking it apart?
    findmeifyoucan, I wish you were wrong..and think you may be right. I will still try to take it apart as someone suggested and look at the mechanism. Seems like there isn't anything to lose as it is likely landfill at this point. Thanks Marcy
    Benimur,
    Tried slamming it..got into it and it didn't help the camera, but I am starting to feel better with the situation. I think it is now landfill. Thanks Marcy
    any other ideas? Marcy
    Smarttech,
    Tried it and it doesn't help. So it looks like all of you tech wizzes are saying it is time to forget about this camera....not good news. I am still going to try to take it apart I believe It is landfill.
    Thank you everyone. Marcy
  • Cameras Master
  • 19,396 Answers
You ruined your camers, but it is still worth fixing.
To repair a shock lens error , like yours the technician wioll need to disassemble and re assemble the whole lens cylinder.
Click here and ask a quote for the repair.
Posted on Nov 22, 2008
  • Ginko
    Ginko Nov 22, 2008
    Can you read my comment?
    Sergeant:
  • 276 Answers
 it says lens error and u have dropped it. 1)try to tap the sides of the camera for few minutes it should get realigned but if still shows the same problem.then its the problem of broken lens. getting it repaired is necessary but it will be costly .but the problem will be fixed. still if you want to go for a new camera it is not a bad idea.  thanks.
    Brigadier General:
  • 6,966 Answers
Offhand, would suggest "go for broke". Jar the camera into action. Hit the bottom with the palm of your hand. Some have reported success jarring it against an open book. If it works, well & good, if not, the cost of repair may no longer be economical anyway. sorry.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    Genius:
  • 1,550 Answers
It is not worth repairing your camera . You have dropped it and internal mechanism is damaged so your having problem in lens mechanism . If you need to fix it will cost you more than $300 .
  • 10,594 Answers
If lens mechanism is damaged then its not worth to get repaired.
As you know camera is already damaged due to drop, you can open it and check / inspect lens mechanism which might be get settled if you pull or push its folding rings gently.
  • Shahid Electronics
    Shahid Electronics Nov 22, 2008
    If lens is damaged, taking battery out and reinserting isn't solution.
    Camera has to be apart to check lens mechanism. In many cases, lens mechanism just got misaligned due to drop. Inspect lens carefully and see is it tilted towards any side? push it to other side so its mechanism grooved might settled.
    Genius:
  • 3,422 Answers
Please try reseting your camera first by removing the battery and mem. card for 10 min.Next insert the battery only and then try turning on the camera.If you still get the error then last thing you can try is tapping your camera on the table surface for 3 times and then turn it on again.
  • Priya darshan Nov 22, 2008
    If you still face the problem then it is the fault with lens mechanism and you will have to get it repaired.If it is under warranty then please get i repaired from Casio.
    Brigadier General:
  • Cameras Master
  • 3,614 Answers
Remove the cam battery for awhile.
put back thebattery camera while holding the power button, and tap on the buttom of the camera to help the lens retract.
  • micromaster
    micromaster Nov 22, 2008
    it was not advisable for you to service and open the camera. some tiny parts and sensitive mechanical parts could be damaged.
    it is better to take the camera to a authorized service center.
My casio EX-S10 lens stuck out and wont turn on even with battery recharged
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
utube.png You-Tube video "AkEfnF6zVxc" placeholder (do not delete) utube.png
Nov 14, 2011 | Casio Exilim Ex-z300 Z450 Z9 Z80 S10
Casio exilim EX-S10 wont turn on and lens stuck out
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here is a video summary of the steps:
Lens error,cannot take pictures or view pictures cause all it says is "lens error",
This is such a common problem that someone has written a blog just addressing this one error. You can read it here - it describes it far more completely than I ever could!
Jan 21, 2011 | Casio Exilim Zoom EX-Z9 Digital Camera
Ex-z9 lens is bent and wont retrack. PUSHING THE POWER BUTTON GETS A LENS ERROR MESSAGE. aNY WAY TO GET LENS UNSTUCK
There is no DYI fix for your damaged lens, and attempting to repair it yourself will likely cause serious damage to the camera. Professional repair is needed to fix this problem.
Oct 25, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
Lens error ex-z9
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 11, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
Lens error on casio ex-z9
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Jul 14, 2009 | Casio Exilim Zoom EX-Z9 Digital Camera
"Lens Error" on Exilim Casio 8.1 mega pixels EX-z9
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 22, 2008 | Casio Exilim Zoom EX-Z80 Digital Camera
Cameras Logo
18 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
