Question about KitchenAid Kitchen Ranges
All 4 stove top ignitors are continue to run all the time. I have shut power off to stove to reset and it does not correct problem. Model kithen aid KGST 307 FWH0
  • sonarman638 Nov 22, 2008
    I paid money for that kind of answer!! You have to be kidding right? Where is some real support on how and where to locate the fix!
    All top ignitors are very clean. I upluged each burner switch individually and they all still keep sparking. I cannot find where the actual spark module is. Finding part locations in unit seems to be very difficult on internet. thanks for any help
    Brigadier General:
  • 3,614 Answers
Do a self checking on the ignators, a possible stucked up on the control.
Posted on Nov 22, 2008
  • micromaster
    micromaster Nov 22, 2008
    Try GENTLY cleaning the ignitor with a Q-tip swabbed in alcohol or else
    follow any cleaning instructions for your range. Generally the ignitor
    senses when the burner lights and stops clicking but it sounds like
    your ignitor is not sensing properly probably because it's dirty.
  • micromaster
    I would take a good look at the wiring at both the module and the
    burner switches. If this is okay, check the wires going to the module
    from the switches. If you turn on a burner switch, this completes a
    circuit adn sends 110 volts to the module which in turn sends spark to
    each of the burners.
Tempstar DC90 pilot light or burner keeps going out. The furnace will run continuously. Even if I turn heat off at the thermostat. I have to kill power at the panel box to get it to shut off. Then I've...
The reset button near the ignitor is a high temperature limit safety switch. When the furnace gets too hot and the manual reset limit switch is tripped, it most likely goes into a 'safe' mode where the gas control is locked out electronically and the blower is made to run continuously to rid the heat exchanger of the excessive heat. This will continue until the reset is pushed and the power is cycled off. It will remain an endless cycle unless the reason for the overtemperature condition is not corrected.
Your furnace 'temperature rise' is getting too high due to a lack of air across the heat exchanger for whatever reason. Some of those reasons could be a restricted air filter or a blower motor that's cycling improperly on its internal winding thermostat. You could also have a dirty air conditioner 'A' coil (evaporator) on top of the furnace restricting the air flow. Nevertheless, you are going to have to have it serviced by a reputable service company's technician to correct what's wrong.
Nov 13, 2014 | Heating & Cooling
Frigidaire Gallery stove top spark module is firing once every 30 seconds when turned off.
ok - this is a question regarding a stove - not a fridge - as indicated.
:D
If the ignitors on a gas stove top continuously spark and only stop when the electricity is turned off the problem may be a stuck relay.
Turn off the electricity (unplug) for a long period of time perhaps overnight. Sometimes the relay will automatically reset.
Aug 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Stove spark lighter won't shut off
The spark ignitor needs to be replaced. You can get it at your local appliance repair store or online at repairclinic,com. That is the way it tells you that it is bad by constantly clicking
May 22, 2009 | Amana AGR5715QDS Gas Kitchen Range
Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
May 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Smoke from top of stove
no it means that what ever spilled on the elemnet drip pan has not completely burnt itself off. replace the drip pan at first chance you get
Mar 23, 2008 | Kitchen Ranges
Ignitor maytag MGR6772BDS gas stove
One of your switches on the gas controls is bad. You'll have to remove the lines from the switches to the ignitor one at a time to figure out which. With the power off, lift the top of the range to expose the controls. There are connectors for the power at each control. After removing one line, turn the power back on and see the result. You'll know when you've hit the right switch. Then, replace it.
Dec 14, 2007 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
Dec 03, 2007 | DCS RGS-486GD Gas Kitchen Range
Kitchen Ranges Logo
62 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
