Question about Kenmore 43142 Front Load Washer
Water does not drain, clicking noise heard no spin cycle
Washer three years old. Water will not drain. Clicking noise heard internally when it attempts to activate the spin cycle.
  • mark chaplin Nov 24, 2008
    46475201 model
    same noise
    it is coming from the pump motor
    it is under the front door behind the panel, remove 3 screws
    unscrew the plug,watch for water,
    the impeller is visible to the right, mine is clicking intermittently, while the drum is spinning
    it does pump out, but not ramp up to spin
    I ordered a new pump unit includes motor
    I will post if fixed
  • 116 Answers
REMOVE DEBRIS FROM PUMP LOCATED INSIDE WASHER ,, REMOVE 2 SCREWS HOLDING BOTTOM PANEL,, PUMP IS PLASTIC TURN COUNTER CLOCK WISE AND REMOVE DEBRIS,, BE CAREFULL HAVE ALOT OF TOWLES STILL HOLD 3 GALLONS OF WATER
Posted on Nov 30, 2008
I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.
Peggy,
“”I heard a noise that sounded like it was grinding marbles and now it will not work and there is water in the washer.””
With the washer not working do you have an error code to the LED display? Can expand on the washer not working?
Do you here the grinding noise in wash/agitate cycle when the tumblers are turning?
If so you need to remove the tumblers and see if there are any coins under the tumblers. See page 37 of the Service Manual.
The SM doesn’t call out the torx driver size required for tumbler removal it’s a #20 torx driver.
You can enter into Service Mode and empty the wash water with this process.
To pump out the excess tub water;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
Rich
Jan 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
Doesnt spin out water
Your lid switch is broken.. to check open and close lid a few times and see if you can heard clicking noises.. if not replace lid switch.. good luck..
Jan 21, 2009 | Washing Machines
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Loud Clicking noise only for the first 30-40 seconds of spin cycle.
You may have something caught in the pump impeller. I have found nails, screws, drill bits, paper clips and other small items that some how make their way past the wash tub and into the drain line. I would inspect the drain pump. Remove as much water as you can. Using a wet/dry shop vac to pull water through the drain hose is the best way to drain all residual water from the pump and drain lines. Remove the inlet line first and inspect the pump impeller. Chances are, you have something stuck causing the impeller to rub against it. If this has gone on too long, you may have some damage to the pump. I hope this is helpful to you.
Jul 05, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 43142 Front Load Washer Logo
217 people viewed this question
Sal De
fordexpert
Robert Rankin
