Question about Panasonic CQ-VD6503U Car DVD Player
My Head Unit stop working/shut down unintentionally
My DVD Player stop working as intended to after a week of installation. It starts to shutdown by itself after 10 to 15 minutes of use and cannot be turn on again except cut down the power to the unit or resetting it through the pin hole reset button. Please help.
  • 2 more comments
  • magik626 Apr 11, 2008
    yeah i have the same problem..it shuts down after 15- 20 min ...help!! plz
  • ralphshummer Apr 28, 2008
    i have the panasonic CQ-VD6505u after 15minutes playing it gets really hot and shuts off then i have to turn off ignition open door and turn hummer h3 2006 back on then radio turns on again but another 15 minutes later it does it again and gets very very hot. please help... thanks
  • Lorissajane May 23, 2008
    Yes, I am having the same problem and have taken it back to Fry's twice. Each time they send it back to Panasonic and say they made adjustments or resoddered connections. Even tried it in another car. It shuts off after 10 minutes and has done this since day one.
  • bmarx4 Feb 19, 2009
    I am having the same problem with the 6505U, were you able to find out how to fix this?
I had the same problem its an easy fix....
Posted on Apr 27, 2008
Yep, same problem. i really really would like to find a solution for this!
Posted on Apr 02, 2007
Mine is doing exactly the same thing! I suspect its a protection mode- the unit is overheating. I'm not sure what to do, there is no mention in the manual.
Posted on Mar 27, 2007
I have a Panasonic surround sound DVD player and the remote has stopped working, I've replaced batteries and tried resetting unit.
Did you fully shut down the player including unplugging. Did you contact mfr customer service or warranty claims for instructions on resetting the remote code in the unit?
Jan 13, 2015 | Panasonic Televison & Video
Sony CDP C-85ES cd player stops and/or shuts down
I have the same player and had this problem. I solved it by getting a spray electrical contact cleaner and cleaning the power button. After spraying inside the button, I just cycled the button a few dozen times and the problem went away.
Sep 08, 2012 | Audio Players & Recorders
My Funai WV805 DVD player quit playing DVDs
Hello
If the DVD do not spins inside the playere, this type of fault can occur. Open the top cover of the player and insert a dvd. See whether it spins inside or not. If not, replace the motor that spins the disc inside. This motor is known as Sled motor.
If disc spins inide and the player do not read or play it, replace the Laser Pickup Unit. It is faulty.
Mar 01, 2012 | Televison & Video
RC10.2DVD player, powers up fine but when you insert DVD it goes it and then right away ejects it with out playing it
Well I just installed this unit in my car and it was fine for a week and then the problem you posted started happening.. I took unit down tried to call RCA mobile but the number is now disconnected so I proceeded to take the dvd player it self out of the unit and found what the issue was there are 2 ribbon cables going to the player and the smaller of the 2 was so loose that it just fell off. So i reinserted it and secured the clamp that holds in and retested it.. And bam the constant running of the loading and unloading mechanism stopped. That damn cable seemed to be the whole damn issue. If your mech. enclined take the unit down remove the cowel on the back side of the unit, open the monitor and u will see 6screw covers either remove them or put ur screw driver right in them and remove the screws and hold your hand on the DVD unit or it will fall completely off when you pick up the housing. Make sure the smaller cable is secure and all wiring is secured and recrew the dvd unit in replace cover and reinstall in vehicle. Hopefully it will work as it did with mine.
Jan 15, 2010 | RCA rc102dvd Car Video Player
NAD T747 Shutting Down
get a fan or do a re-stack...open the back of the e-center, Yes it will do a thermal shutdown... just like 3 mile island
Dec 10, 2009 | Audio Players & Recorders
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Computer shuts down on inserting disc
I have just fixed a computer with a similar problem. The owner installed a new DVD burner (a SATA drive) and every time he inserted a CD or DVD disc, the computer shutdown (mostly, because the front LED was still on and the CPU fan too, everything else just turned off [drives, PCI cards]). It happened in Windows, in Linux (Ubuntu) and even in the BIOS screen, so I discarded an OS problem. Also happened while booting if a CD or DVD was already inserted in the unit; as soon as the drive LED blinked, the computer crashed. After checking the obvious, I did three final tests:
1) try the DVD unit in another computer (it worked);
2) try the DVD unit with the power connector only, with the data cable disconnected (it shutdown);
3) try the DVD unit with the power connector from and external power supply, with the data cable connected (it worked).
By this point, it was obviously a power supply problem. I checked the power supply unit (PSU) and discovered it was pretty small (250 W). So I installed a more powerful one (350 W) and then it worked.
I checked with a wattmeter and it seems this DVD drive increased the power consumption by 25 watts when started to spin the disc. I really don't know if that is normal (taking 25W to start spinning the disc) or if this drive has some defect, but it seems the previous PSU could not provide that extra power and shutdown some of its output (but not all).
So, if you have this weird problem, maybe checking the power supply and testing with a bigger one may help.
Regards,
MV
Jan 31, 2009 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
Head unit not working n-2
Sound like your ribbon cable is on it way out. Check out Ebay, they do carry replacement. Goodluck.
May 24, 2008 | Pioneer AVIC-N2 Car DVD Player
Kenwood kvt 911 dvd head unit
I have a question. Everything is working perfectly except for there is no picture on the TV nor DVD. It was working fine until the other day when I messed around with some wires seeing if any of them were loose. Any suggestions?
Dec 09, 2007 | Kenwood KVT-617DVD Car DVD Player
Subwoofer Shutdown
Whay don't you take a look at your data cable and jack contacts to see if any of them are bent or misplaced. Terry
Oct 02, 2007 | JVC TH-C50 System
Panasonic CQ-VD6503U Car DVD Player Logo
276 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
