Question about Hoover Vacuums
How to replace vaccum belt on a hoover tempo - Hoover Vacuums
  • NannaLuvs Feb 06, 2009
    We changed the vbelts. the brush is not turning what could be the problem.
    Scholar:
  • 55 Answers
Turn the machine upside down. Take the screws out of the bottom plate and remove it. take out the brush roller and old belt. Wrap the new belt around the metal shaft of the motor first and put the roller inside the belt loop and use the roller as leverage to stretch the belt up to the brush housing and slide the roller in place. Give the roller a spin by hand the make sure everything moves freely before you use it. It should spin with out much effort, if it doesn't you probably have the belt pinched, and you need to free it up before putting the bottom plate back one. It will take a little elbow grease, but it will go on.
Hoovers usually list what kind of belt they take on the serial tag.
Good Luck
Posted on Nov 24, 2008
Hoover Widepath Tempo - belt slips off when we start it. Can you help?
Perhaps the belt is stretched. Replace it with Hoover belt # 38528-033. Remove the rug plate on the bottom ( 4 screws ), and remove the brushroll. Place the belt around the motor shaft first, then position it around the brush, and push the brush back into the housing. Expect resistance from the belt, as it must be stretched several inches. After the brush is in place, turn it with your fingers to be sure the belt is centered, and not pinched between the brush and the housing. After replacing the bottom plate the vacuum should be ready to use.
Feb 18, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Is it possible to download a user manuel for a vacuum? I purchased mine out of the box.
hi!!! looking the picture of your vaccum, it must be the U5140900.
here you are the manual for that vaccum:
http://www.hoover.com/pdfs/manuals/U5140900.pdf
if yours is a different model, please send me the number.if this help you dont forget to rate my solution!!
have a nice weekend.
jess
Sep 17, 2010 | Blair Hoover Widepath Tempo Bagged Vacuum...
Hoover Tempo Widepath - propellor not working
If you are refering to the roller underneath, the belt nees to be replaced. Simply remove 4 bottom screws and then the roller, Place new belt on roller and thenon motor shaft, pull belt with the roller to install in position and install bottom plate.
May 02, 2010 | Hoover Tempo Widepath Upright Vacuum -...
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
Burning smell
the belt needs changed. its slipping. make sure its not clogged with carpet or string ect. first. if not buy a belt at walmart. in stock...
Sep 08, 2009 | Hoover Tempo Widepath Upright Vacuum -...
No suction on my vacuum. Hoover Tempo
try to clean between the roller and the tube to the hose
May 05, 2009 | Vacuums
Changing a vaccum belt
Most of the Dirt Devils, turn the vac. over, remove the bottom plate, then you can get to the belt and brush roll. If the bottom plate doesn't come off, then from the top, there will be 2 or 3 screws to remove, then the top cover comes off to reveal the belt and brush roll.
Nov 03, 2007 | Vacuums
Hoover Windtunnel
Your belt may be twisted inside-out. Be sure the printed marks on the belt face away from the pulleys and shaft. The printing should face you.
Oct 22, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
125 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
