Question about Whirlpool GGQ8831L Gas Dryer
Natural gas dryer gets very hot during some drying cycles
We have a whirlpool model #ggw9250pw3 dryer.there are times in bulky mode and heavy duty mode that the right side of the dryer gets so hot you can not keep your hand on it for any length of time.this is a natural gas dryer. i have rerouted the vent to the side of the house shorting the distance to about 4 feet from 20 feet as we had a roof vent.we clean the vent after every load.
  • 4,806 Answers
Check to see if the heating element is grounded to the canister or the bracket, if it is, the element would never shut off when the timer is on even with the motor not running. Turn the dryer to timed dry but do not start the dryer. Open the door and watch the rear left side to see if the element comes on, glowing orange/red/ If it does with the motor not running you know this element is grounded. If both of these check out, you might have a bad cycling thermostat.
here is where to get the spare parts:
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
regards
Posted on Nov 22, 2008
  • Lee Hodgson
    Lee Hodgson Nov 22, 2008
    check the thermal fuse also, it could be defective
    regards
    Genius:
  • 1,239 Answers
HI SIR THIS IS YOUR ACTUAL PROBLEM
The door of the dryer is sealed with one or more gaskets to keep the hot air in the dryer from escaping and prevent the cool air in the laundry area from being sucked into the dryer. A deteriorated or damaged gasket greatly lowers the efficiency of the dryer. To check the gasket, hold a sheet of tissue paper near the rim of the door while the machine is running. If the door leaks, the paper will flutter. If the gasket or seal leaks, looks worn or warped, has chunks of material missing, or feels hard and nonresilient, it should be replaced with a new gasket of the same type.THIS IS THE 100% ACURATE ANSWER TO THIS PROBLEM.PLEASE RATE IT.
THANK YOU...........RATE IT PLEASE
    Brigadier General:
  • 3,614 Answers
You may need someone to inpect and check the condition of the unit and it parts inside., some cleaning on the parts inside may needed
My whirlpool duet dryer will not allow a normal cycle, it swicthes to delicate or bulky items
The control board is failing... I would use it until it will not dry clothes at all, then get it rebuilt for a fraction of what a new control costs. CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
This place rebuilds controls and offers a one year warranty for about 130 bucks
May 22, 2016 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Electric Whirlpool dryer won't cool down during drying cycle and even gets hot during air fluff cycle. Replaced thermal fuse and is still the same.
There are two thermostats on my whirlpool model number 857554115010.
Both should be replaced at the same time.
I found a good video on
http://www.espares.co.uk/advice/tumble-dryers
I bought the parts from them and it worked.
Sep 12, 2013 | Whirlpool Dryers
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
The beep that signals load is done sounds prematurely for about a minute ,the dryer continues until load is dry then shuts off
On this dryer each of the seven automatic cycles listed on your machine perform different functions based on fabrics, load size or variables. In essence the first four settings (Heavy Duty to Delicate) relate to your desired drying temperatures of high, medium, low or extra-low respectively. The moisture level of the load is determined by the dryer's sensor system and the machine will set the drying time to an optimal level.
Whirlpool added a WRINKLE FREE feature or what one might describe as an extended intermittent tumbling time. This added cycle helps reduce wrinkling when you may not be able to unload the dryer immediately after the end of the cycle when the buzzer goes off. Starting this setting is a simple one button operation at the control panel. TheWrinkle Shield™ Plus Feature is preset to on during the permanent press cycle.
Jan 30, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
Whirlpool model # lgr7646ez3
Here are a list of causes that may contribute to this lack of sufficient drying.
CAUSE
• Lint screen is clogged with lint.
• Restricted air movement.
Exhaust vent or outside
exhaust hood is clogged with
lint.
• Exhaust vent is crushed or
kinked.
• One fuse is blown or circuit
breaker is tripped. The dryer
will appear to operate, but you
will not get any heat.
• Cycle Control knob or temperature
selector is set on air dry.
• Load not contacting the sensor
strips and automatic cycle
ending early.
• Fabric softener sheets blocking
exhaust grill.
• Dryer located in room with
temperature below 45ºF (7ºC).
• Large amount of moisture in
the load.
• Cold rinse water used.
• Load too large and bulky to
dry quickly.
Here are the solutions to combat the issues.
SOLUTION
• Clean lint screen.
• Run dryer for 5-10 minutes. Hold hand under
outside exhaust hood to check air movement. If you
do not feel air moving, clean exhaust system of lint
or replace exhaust vent with heavy metal or flexible
metal vent.
• Replace with heavy metal or flexible metal vent
• Replace fuse or reset breaker.
• Select the right cycle and temperature for the types
of garments being dried.
• Level dryer.
• Use only one softener sheet per load and only use
it once.
• Move dryer to a location with temperatures above
45ºF (7ºC).
• Expect longer dry times with items that hold more
moisture (cottons).
• Expect longer dry times.
• Separate load to tumble freely.
This will help you fix this problem. i suspect an exhaust obstruction.
Mar 11, 2009 | Whirlpool LGR7646E Dryer
Gas Dryer - takes to long to dry
Friend,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.If the vent line is kinked or blocked
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
Take the vent line off the rear of the dryer and try if it works. If it does you know it's the vent line and not the dryer that's the problem the dryer.
You will be fine
Bless You huuum
Feb 01, 2009 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
23 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
