Question about Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor
No video output
I have a second hand samsung syncmaster 710N LCD monitor. After connecting power and data cable properly, i turn on my pc. But there's nothing picture's come out. The power green LED is on. Could u tell me what would be the possible fault? If i repair this problem, does it cost alot? Thanks in advance..
  • 2 more comments
  • EdRo1212 May 27, 2008
    I received 2 of these monitors as new/unused excess from another Federal contract. When you connect them to the computer, they display a message about the screen resolution not being optimal. They call for 1280 x 1024 at 60 MHz. Then they do nothing else. I have tried setting the computer to that resolution (using another monitor that worked fine) and also adjusted the hertz setting and reconnected the Samsung monitors but they still did nothing but display the same message which scrolls across the screen. If disconnected from the computer they display nothing which I presume means that they are receiving a signal from the computer and can at least recognize that fact. I have tried this on quite a few different computers and have switched the video cable to try some other ones but still get nothing. I am running Windows XP 2.2. Any thoughts on this? I hope I have not gotten two duds.
  • cliff119 May 29, 2008
    I have a SyncMaster 912n flat screen monitor, three years old. I have connected the screen to two different computors, nothing, black screen. I had wonder service from the monitor up until a month ago...upon a reboot yesterday, nothing
  • Anonymous Jun 11, 2008
    I have the same problem with two SyncMaster 710N monitors. Neither display any picture and if I test the monitor all tests OK but no output from PC to monitor. Any suggestions???
    They are about to get drop kicked into the skip! :-)
  • dark-joy Jul 28, 2008
    I have the same problem i tried to connect that monitor in another Pc and it works 1 or 2 hour and the screen it's start to waste and then i don't have screen it's returned the same thing what i have in first Pc i don't have video output.
    I tried to reset many times but that can not help.
have the same problem as above,
solution number 4 from jay klein worked 100%
problem gone...
thanx
Posted on Aug 27, 2008
    Problem Solver:
  • 5 Answers
  • 3 Answers
I have the same monitor connected to my wife's computer. Here's what I did and it worked!
1. Disconnect the monitor cable from the computer. If the check signal cable message comes on, the monitor should be ok.
2. LEAVE THE MONITOR POWER SWITCH ON..DO NOT TURN IT OFF. Unplug the power cable from the back of the monitor and wait about 30 seconds.
3. Plug the signal cable back into the computer.
4. Plug the power cable back into the monitor.
5. Hopefully this will work!
If you do the standard turn the monitor off and then unplug the power cable, it doesn't fix the problem. You have to LEAVE THE POWER SWITCH ON ON THE MONITOR. Somehow this resets it...at least on mine.
Please let me know if this works on any of those monitors.
Posted on Jun 09, 2008
Maybe the power source is going bad, check the 800 volts altern.
www.serviceya.net
Servicio técnico Monitores LCD Samsung LG 1 hora
Posted on Apr 11, 2008
Aung, I have also a second hand 710N, and I have the same problem. Do you reach any solution for your monitor!?
Posted on Feb 14, 2008
How to solve a samsung 710n A tft error message not optimum mode recommended mode 1280*1024 60hz in windows xp
It wants you to set the PC video card video output to its native resolution (1280*1024 60hz). Are you running the PC resolution on this mode? otherwise you can turn off the resolution warning by going into the monitor on-screen setup menu to turn off the resolution warning.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Sep 08, 2011 | Samsung SyncMaster 710N 17" LCD Monitor
When I open the Monitor (samsung syncmaster 710n) everything is OK! As I soon as I connect the vga cable from my pc the monitor turns on stanb by mode and does not react to any buttons!
It sounds like you are connecting with the power on. NEVER do this!
Shut off your computer AND your monitor. When both are off, THEN connect your cable.
Then you can turn the PC and monitor on (the proven old school way is to turn on monitor first, then PC)
If nothing was damaged from connecting them "live", you should be OK.
Feb 10, 2011 | Samsung SyncMaster 710N 17" LCD Monitor
I have a samsung 17'' lcd monitor.when i power on my monitor without data cable i got a message on screen CHECK SIGNAL CABLE.when i connect data cable my lcd is going to power off.please help?
The message says that the monitor doesn't receives signal - which is normal. Since the problem appears only after you plug in the cable in means that the problem is located there - something is wrong with your pc, most likely the video card has died.
Oct 03, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung Syncmaster 710N PROBLEM !!!
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 10, 2010 | Samsung SyncMaster 710N 17" LCD Monitor
I have the syncmaster 710N. I recently had a
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Feb 24, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
Samsung Syncmaster 710n no display and no LED light
The power button should be on the FRONT BOTTOM RIGHT. and there should be a little led/light next to it. make sure everything is plugged in correctly and press the power button, the led should light up, and then boot your computer.
Let me know --
If this helped please mark this thread as FixYA
Dec 26, 2008 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
I have 2 samsung 710N LCD monitors that are exhibiting the same symptoms. When they are powered on, they display fine for about 10 seconds, and then go completely black. If you turn them on and off again,...
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
thank you
Mar 19, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
Problem LCD screen stays white bright after switch button is OFF ??
Some capacitors need to be replaced,which would have burnt out due to power fluctuations
May 12, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor Logo
475 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
