Hi Im rewiring my screen cable and I found the wire diagram for the screen but it revers to kb2,ST,DSCL and DSDA. What does it stand for and what pins should it be connected to?
hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this at reliable-store
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
Well that depends. What do you want it to do after you rewire it? Are you wanting to install new pickups or add any features? One of the best sources I have found for wiring diagrams is Seymour Duncan. They not only have listings for how to wire their pickups, but also many of the common wiring diagrams for many guitars. Please only do this if you feel comfortable with soldering. Otherwaise, take it to a local luthier.
This could be a problem with the monitor's data cable. Try to check it & find if there is any bent pins on the connector. If
this is not the case, there could be a loose connection on the
monitor's PCB, or a failing component. This needs to be checked by a
qualified technician.
If you want to rewire the vehicle, assuming that you will not be changing any systems, you can usually find complete new wiring harnesses from both the dealer and from aftermarket selllers like Quadratec and JC Witney. Buying the complete wiring harnesses will be alot cheaper and less time consuming than trying to make them yourself. These wire assemblies are just a plug and play deal, you disconnect a harness and replace it with the new one. They may even include some instructions. If you need further assistance with custom wiring or diagnosis, I would recommend getting the service manual for the vehicle from the dealer or used ones from eBay ($30- $100). The factory service manuals have complete wiring diagrams and schematics as well as full diagnostic information. These service manuals are NOT like the ones found at your local parts store (Chilton or Haynes). The factory service manuals are like complete blueprints for a car.
