My maxtor drive doesn't work as a slave drive. It is recognized by bios but not by windows XP
  • 189 Answers
Maybe your hardisk is not compatible with xp, was it an old hardisk? Try it with other computer if it detect.
Thanks
Posted on Nov 22, 2008
I installed a Maxtor 4R080L0 as a slave drive. My Windows Explorer (XP) cannot "see" the drive. - It is recognized by the BIOS. - It is properly listed in the Device Manager and 'running properly' - Win...
You will need to go into the control panel, administrator, and then disk drive manager. once there you will need to initialize the new drive and then format the drive before the system will see it. Format using the NTFS file system only if you are using XP, After the format is completed reboot the system and your new slave drive should show up just fine and you will be able to log into it or use explorer to view it.
Apr 14, 2017 | Maxtor QuickView (4r080l0-qv) 80 GB Hard...
I have an old (1995) maxtor disk model 71626AP out of my old computer. I think I want to install it as a slave in my windows/XP desktop computer. Other than removing the jumper at J20, is there anything...
Windows will recognize it. Just be sure the other drive is jumpered as master/primary and the old drive is jumpered as slave/secondary and that they connect to the same IDE cable.
Aug 28, 2010 | Maxtor Hard Drive
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
My maxtor D740X-6l 40GB drive will not boot up. I can hook the drive up to another computer and read the files but it will not even show as a drive on the original computer. The first computer recognizes...
all you have to do is to simply set the jumper at the back of he hard disk, beside where the IDE cable and power enter into the hard disk.
Just keep setting till you put at the right position where the system recognizes it.
There is nothing wrong with your PC and hard drive, just set the jumper of the Hard disk and that should be all.
Take care.
Jan 04, 2010 | Maxtor Hard Drive
My vista computer doesn't recognize my maxtor one touch 4 external harddrive...it doesn't recognize it on my xp either how can I fix this...I have a lot of stuff backed up on this and it is less than a...
HI,
What I would suggest, is to take the drive and install it as a slave drive. Make sure your pin settings on the drive are set to slave, and your main drive is set to slave. Then XP and Vista will recongize it so you can pull the data off it, then reformat the drive and see if you get any errors.
Good Luck
Mark
Oct 27, 2009 | Maxtor Hard Drive
How do I make my MAXTOR Hard Drive 7Y250M0 a slave?
A slave drive is defined by removing the jumper (pin sleeve) completely from the drive. Then go into your BIOS and if it doesn't auto-detect as slave, manually change the settings and you'll be good. You shouldn't have to go into your BIOS.
If you can see it as slave in BIOS, but not in Windows that means the drive is not formatted properly and to do so, Right click on My Computer in Windows and goto Manage. It should load the Computer Management window. From there goto Disk Management under Storage in the left side browser. You should see the Hard Drive there, right click on that and format it.
That should do it.
Dec 12, 2008 | Maxtor 7Y250M0 250GB Serial ATA 7200rpm...
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Maxtor diamondmax plus 9 6y080l0
IDE AND SATA CONTROLLER PROBLEMS ON MAXTOR DRIVES.UNINSTALL CONTROLLERS AND REBOOT,DO NOT PLUG IDE DRIVE IN.THEN REBOOT AGAIN PLUG IDE DRIVE AND LOOK IN DEVICE MANAGER IF DRIVE IS RECOCNIZED CORRECTLY.(ASUS BOARD) OR INTEL CHIPSET PROBLEMS.
May 20, 2008 | Computers & Internet
Failed to load to windows XP
wow yea it's looking for grub/linux i did that same thing once you need the xp install disc insert that hopefully you can get into your bios then go and set it to boot from disc restart and go through the options till you get to repair and type in fixmbr
Oct 06, 2007 | ASUS P4PE Motherboard
HDD not recognized in XP Installation
if you are using it as a slave hard drive, you should be able to right click my computer, manage, then in next window double click storage, then disk management, then look for your drive, you can then look to see if its recognised, if not it will tell you that its not configured, and you should be able to right click on it and format it.
Jun 07, 2007 | Maxtor DiamondMax 10 300 GB Hard Drive
Computers & Internet Logo
Alun Cox
David Payne
David Payne
