Question about LG Televison & Video
Audio problems with surround speaker system on
I have a thomson digi box, and a surround sound system (jvc) with built in dvd player and an LG model 32lg3000. The sound on the tv is fine and dvds play fine with the surround, but when i try get the sound through the surround while watching tv through the digi box it sounds poppy and it sounds like it isn't on the right channel.
  • 68 Answers
I have had the same problem on my home theater maybe you should try to wiggle the speaker cord it could be loosly hooked up to your home theater
Posted on Nov 22, 2008
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
Hi, I bought recently a new 5.1 Surround Sound System Logitech X-530 and want to connect it to our new LCD LG 32LD450 HD TV. The LG TV has apart from all Digital, Optical and RCA Connections as well one...
You can't connect the speakers to your TV. I doesn't have any audio output available, just inputs. Those are for connecting the audio from sources like DVD players, and they go in to the TV's sound system. But there's no way of getting the sound out except through the set's internal speakers. The surround system you got is great for a computer, but it's not what you need for TV use.
The only solution I can offer is the suggestion that you invest in a home theater receiver. You can get decent basic systems with the receiver (often with DVD/audio CD playback capability built in) and surround speakers at reasonable prices. Then you use that to drive the speakers, and use the TV just as a video monitor. Then you will have surround sound.
Jun 01, 2011 | Logitech X-530 Computer Speakers
I have a 5.1 jvc dvd surround system and have just bought a 37'' new lg tv. The system plays in stereo when listening to just tv. It does not have an HDMI connection on the DVD. Can i update with a blue...
Your LG tv should have an optical output socket,if your surround system has one as well,(input) then connect an optical lead from the tv to the system,then select either input 1 or opti 1(depending on your system) you will then get the sound from whatever you are watching on the tv
Nov 04, 2009 | Televison & Video
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
No audio from dvd player
you wil get the sound from the surround speakers only but not from tv first connect all the speakers that are given to the player correctly then you can get perfect sounds with dts...
May 04, 2008 | JVC TH-A25 System
Setting Up Surround Sound with satellite tv digital tuner
What model do you have?
You should be able to plug the audio/video output from the satellite TV system into the audio/video input on the JVC system. Then set the JVC system to the appropriate input.
I need to know the exact model to know how or if this is even possible. Some JVC models don't let you input any additional devices. Others might not have the inputs that are necessary for surround.
Mar 19, 2008 | JVC TH-S5 System
How do I get surround sound from TV?
see if ur DVD player has a TV/Audio in....you have to set it up so u watch TV threw your DVD player (if you have one of of the Surround Sound in a box systems) if you have SS w/ a receiver then you'd have to run Audio out from your TV/Cable/Satellite to the receiver for it to work
Feb 02, 2008 | Jensen JHT805 System
Dvd player is locked
Ideas
1/ Turn power off for a while at powerpoint for as long as you want 5mins should be fine then turn on and try again.(which youve probably done already) as well as looking up your model number on the net to attain a info on your system.
Does the remote still work if so try to find unlock in menu/setting/functions but if it requires a digit code then youll need the manual as it could have an override built for cases such as yours.
start at jvc.com/dvd5.1 surround and find your model
good luck
Clapster
Jan 28, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
Televison & Video Logo
347 people viewed this question
Computer Repairing
Computer Repairing
