Question about Hitachi 50V500 50 in. HD-Ready LCD Television
I cannot turn off the closed caption on my Hitachi 50v500
The captioning was on auto, the TV was turned off, when turned back on the closed caption is on and I have been unable to turn it back off. I have reset the settings repeatedly, turned the unit off and back on.
  • pdreher Dec 23, 2008
    My dad has the same TV and has the exact same problem. Any ideas? N
  • John Coiner Jan 12, 2009
    I have the same problem on mine. been that way for 6 months.
5 Suggested Answers
circuitcity
  • 137 Answers
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Posted on Dec 09, 2007
SOURCE: Closed captioning
I experienced the same problem for about an hour before recognizing that the "continuous on" closed captioning had been activated on my cable box, not the TV. The signal feeds through despite the CC settings on the TV. If you haven't already, try checking the CC settings on whatever device is supplying your video.
Posted on Oct 12, 2008
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Posted on Jan 30, 2009
SD Tech
  • 14553 Answers
SOURCE: I can't turn on closed captioning on Hitachi with Comcast scientific atlanta explorer 2200 cable box. Any words of wisdom?
Both the set and the box used should have the closed caption feature.
If box is in line to rear audio/video jacks you will have to engage the CC from the box.
I doubt it will work if hooked that way from within the box---go to menu and in CC area in either set or box select CC1 which is the most common one used.
Posted on May 25, 2012
May 25, 2012 | Hitachi P50H401 50 in. Plasma HDTV
How to remove closed captioning on a hitachi ultra
closed caption can also come from a cable or satellite box if you are using one--either it is from the set or the box----either can cause it.
SD TECH
Jun 03, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Close caption never leaves the screen
Go into your MENU most likely under Audio and look for Closed Caption, it should say on the screen which controls on the remote to navigate with. It might also be under Features you will then be able to turn it off.
Feb 05, 2009 | Hitachi 53SWX12B 53" Rear Projection...
Closed caption
Are you talking computer or TV?
Closed caption on a TV is when the volume is muted and it prints the speech in a box on the screen. You have to turn it on in the menu.
Nov 27, 2008 | Computers & Internet
Black box covers most of screen some channels, plus gibberish.
it is the closed captions on the tv. it is set to closed caption text. turn it off
Nov 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi model 42V715 television close caption problem
Hello ccharewicz, After you apply the cc settings do you turn the tv off and then back on. Also have you tried unpluging it from the outlet, sometimes either of these work, if they don't then please post again and i'll continue to look into the problem.
-I look forward to your post
Nov 12, 2008 | Hitachi 42V715 Rear Projection Television
Spanish closed captioning stuck on Tobisha 46RV530U
Did you change the language to English? turn off closed cap.?
Jun 01, 2008 | Televison & Video
Closed captioning
Apr 22, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Closed caption will not turn off on my TV even though it is turned off...please help...You can e mail me at Bluedevils1133@hotmail.com
Did you check your cable box or satellte box set-up? I thought I had the same problem on my Hitachi 46F500 but it ended up being my Comcast box was set-up to display closed captioning on the component video output ONLY. Hope this helps...
Oct 16, 2007 | Hitachi 53SWX12B 53" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
169 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
