Question about Weber Baby Q Grill
Hard to iqnite Baby Q grill
I always attempt to light the grill setting the dial in the correct place. It never lights on the first attempt as it used to. Sometimes after 8-10 attempts I give up and use the George Foreman grill in the kitchen or the stove's broiler. Other times after 3 or 4 attempts the grill ignites but with a huge flare up that nearly tinges my eyebrows and/or clothing. Not good.
What's the problem and how do I fix it?
Ron Beach, Grand Junction. CO
  • ronandlouise Nov 24, 2008
    I tried smitty881's suggestion and it worked on the first attempt to ignite my grill. Problem solved. I had always had the lid open when igniting and sometimes it would ignite and sometimes it took many attempts or I'd just give up. Thanks. Ron
    Problem Solver:
  • 11 Answers
Do you leave the lid down when you ignite the unit? I had this problem with another brand of grill but when I leave the lid down and ignite the grill, it works perfectly.
That said, call Weber Customer Service and share the problem with them. I've never found a better customer service department than at Weber.
PFSmith
Posted on Nov 23, 2008
Side burner lights but not main burner on gas grill
If you smell gas, don't attempt to light the burner. Instead, turn the gas off and inspect the fuel tank, lines and burners once the smell of has has cleared. Always grill where you have adequate ventilation and perform all repairs only after the grill has fully cooled from use.
home lights
Jun 07, 2012 | Char-Broil CharBroil Master Flame Gas...
What is the temperature range on the dial? Is "high" on the dial the hotest temperature or does it get higher the more you turn the dial? Not able to get a really high temp on our...
High is the highest and hottest setting/temperature. Depending on how long you preheat the gill with the lid close, will determine what the maximum temperature will be.If it's not heating well, the burners may need to be removed and cleaned. The link below is for the Baby Q Model. Pay particular attention to the Annual Maintenance Section, as it will show you how to remove the burner(s) and clean them.
http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/BabyQ_OwnersGuide_41636_060205.pdf
I hope this helps you and Thanks for choosing FixYa. Happy Grilling!!
Jul 27, 2011 | Weber Baby Q Grill
I don't seem to be able to get the Brickettes Hot
Whether using a gas canister or a tank, To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank. Or remove the canister from
it's holder.
2. Wait 5 minutes and reconnect the hose to the tank. Or reinstall the canister into the holder.
3. Open the tank valve or canister valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
any remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
Hope this helped you and thanks for choosing FixYa. Happy Grilling!!
Jul 26, 2011 | Weber Baby Q Grill
No smell or sound of gas when I turn it on
it's holder.
Jul 25, 2011 | Weber Baby Q Grill
I cannot get a flame going on my grill - it has slowly stopped - I've taken everything out and cleaned to the nth degree - replaced the grill regulator; replaced the gas tank regulator, etc. The dial...
Here's the problem and the solution. The new regulator you just installed, locked up when you turned ON new tank. This oocurs quite frequently with the fairly new OPD equipped grill tanks.
Solution:
1. Turn the gas tank's valve OFF and disconnect the hose from the tank.
3. Open the tank valve VERY, VERY, SLOWLY (slow motion, slow),
4. Once the valve is fully open, light the burner farthest from the tank first and turn it to HIGH.
Did the burner light and does the flame height look correct? If so, light the remaining burners
the same way. Now, do all the flame heights look correct? If so, you solved the problem (with
a little help). Remember to ALWAYS open the tank valve very, very, slowly.
Happy Grilling!!
Jun 23, 2011 | Viking Grilling
My7 Baby q doesnt get hot enought to sear steaks
Their are several things that can cause this problem:
1. The burner(s) need to be removed and thoroughly cleaned.
2, Low amount of gas in the tank.
3. The grill's gas regulator is partially seized.
The first two are easy for you to solve, The third one is to if you do the following:
Turn the gas tank valve OFF. If you're using a 20lb LP Gas grill tank, disconnect the hose from the tank and wait 5 minutes, If you're using a small 1 lb cylinder, turn it OFF and remove it from the grill. after 5 minutes, reconnect the hose to the tank or reinsert the small cylinder and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open light the burner(s) and turn it to the highest setting. Did the burner light and does the flame height look correct? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly.
If the above didn't solve the problem, you will need to replace the grill's hose/regulator assembly (if you're using a 20Lb LP Grill Tank). Which you can find at any home center or hardware store that sells gas grills and accessories. If you're using the smaller insert-able tank, you will need to replace the tank's hookup and regulator mechanism.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Jun 03, 2011 | Weber Baby Q Grill
Baby weber starter not igniting, will light with match. how to correct
You have to replace the igniter. www.ibuygrillparts.com
Apr 21, 2011 | Weber Baby Q Grill
Low temperature Only hitting 300 degrees Has gas It's warm outside as well
Two problems - Two Solutions: Turn the LP tank valve to OFF. Disconnect the grill hose from the tank and do not reinstall for 5 minutes. After the 5 minutes, reconnect the hose to the tank and turn the tak valve ON VERY, VERY SLOWLY (slow motion, slow). When the tank valve is fully open, light the burner farthest from the tank and turn the flame height to HIGH? Does the flame height look correct? If so, light the remaining burners the same way. If all the flame heights appear to be normal for the highest setting, you've solved the problem.
Second problem & solution: The grill thermometer may be incorrect (as they often are). If you don't have one, buy an inexpensive oven thermometer (that normally sits on the oven rack) and place it on the cooking grate of your grill, toward the front of the grill. Once in place, preheat your grill as you normally would with the hood closed and at about the 15 minute mark, compare the temperature on the two thermometers. If they're within a few degrees of each other, your grill thermometer is accurate. If the Oven thermometer reads higher (more than a few degrees), the grill's T-Stat is faulty.
Personally, I always use an oven thermometer on my grill when grilling or baking anything.
Hope this helped to solve your problem. Please let me know and Happy Grilling!
Mar 16, 2011 | Weber Genesis Silver B Grill
How do i set timer to turn lights off and on
If I understand correctly, you have Intermatic electro-mechanical timer that has a yellow clock dial on front
And you want to set the timer to turn lights on and off
And your wiring is correct and the manual override turns the lights on-and-off correctly
To set timer:
Pull dial back toward you. Rotate clock dial until current time lines up with silver pointer.
On other brands of timer, you rotate dial until current time lines up with an arrow or the word 'time' located on lower right of clock dial
Timer has on-off trippers that fit outer edge of dial.
Intermatic trippers are labeled ON and OFF
Other brands of timer have dark and light-colored trippers >> I think the dark trippers on some brands are OFF
Place 'off' tripper when you want timer to turn off
Place 'on' tripper when you want timer to turn on
Turn on electricity and expect timer to run for 20 years
Dial has to be re-set to current time after power outage
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Oct 20, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I am scared to death of gas grills -- nearly burned my hair and eyebrows off years ago -- husband always lights it -- he's out of town -- how do I light a Weber gas grill?
Be sure your outdoors in the open. Be sure that the cover is off. Use a large match stick (fire place)or a butane grill lighter to burn the gas. Place the lite match/lighter to the burner head and open the gas bottle. After 6 seconds, If the burner head does not light shut the gas bottle off. Try again till it lights.
Aug 15, 2010 | Weber Gas Go-Anywhere Grill
Weber Baby Q Grill Logo
472 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
