Question about Samsung PCJ522R 52" Rear Projection Television
STRING Testing TExt Mode
I have a Black box that comes up covering the entire Screen. IT READS: This is a string to test text mode start up message function... Please if anyone can inform me on how too fix this problem Please email me.. Thanxxxxxx Billfurd
  • 3,130 Answers
Re: STRING Testing TExt Mode
Bill, it seems someone has turned on the closed caption feature on this set. There is a button on the remote control thatsays Cartion. Press it till you turn the caption off. This will not be on a universal remote, only the original remote. Good Luck Please do not forget to rate this thread.
Posted on Dec 26, 2006
0 characters
3 Points
Black Message Window
I'd say that your processing board is on a downhill slide, with memory telling you it's almost over the edge.
Mar 16, 2008 | Hitachi 50DX01B 50" Rear Projection...
Black box covering part of screen
That is coming from the closed captioning. It has been turned on and it is in text mode. The captioning is most likely coming from the television but it can also be coming from your cable box/satellite receiver. Find your television remote's cc button and press it until it says off on your screen. If your remote does not have one closed captioning should be in the menu. If the text box is coming from a cable box there are a couple of ways to disable it not limited to a button on the remote and a hidden menu you can access when turning it off from the on off button directly on it and pressing the menu button located directly on it.
Keep in mind also that closed captioning can also come from your cable box or satellite receiver.
Sep 28, 2010 | Hitachi 53FDX01B 53" Rear Projection...
This is a string to test text mode problem
tienes activado la funcion de subtitulos debes desactivarla
Aug 26, 2009 | Hitachi 60EX01B 60" Rear Projection...
Black box in middle of tv screen
This is a background for text, even though you aren't seeing any text at the time. Since it covers most of the screen, it sounds more like a demo mode screen than closed captioning. Go into your setup menu and make sure that neither of those is selected. If necessary, restore the factory settings. I'm assuming that this is coming from the tv itself, and that you don't have a VCR, Tivo, etc. Good luck!
Jun 15, 2009 | Hitachi 50UX57B 50" Rear Projection...
Tv screen goes black and says string to test text mode?
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it may be also cathode ray tube... thank u.........
Jun 02, 2009 | Hitachi 60EX01B 60" Rear Projection...
Black box on screen
Check your closed-captioning setting and make sure captioning is turned off (or set for captions if you really want them). You'll find it's set to "text" mode right now. The set is blanking out a portion of the screen to display text it never receives, and you'll only see this when you view a channel where captions are being broadcast. Most sets have a button on the remote for captions, and it's easy to switch modes without knowing it. Then you wind up with the mysterious black box.
If this helps you out, please take a moment to rate the solution. Thanks for asking here!
Feb 18, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
A black box sometimes appears on my tv screen. can you tell me if this is from having the closed caption butten on and why it happens?
Yes, if the closed caption mode is turned on in 'text mode' the set will display a black box even when no closed caption text is available. the normal closed caption mode is cc1. try turning closed caption to cc1 or off. tech7
Jan 04, 2009 | Projection Televisions
String test
Possibly the closed caption feature on this set has been turned on. There is a button on the remote control that says Caption. Press it until you turn the caption off. This will not be on a universal remote, only the original remote. You can also turn this off through the caption section on your on-screen menu.
Jan 22, 2007 | Samsung PCJ522R 52" Rear Projection...
Samsung PCJ522R 52" Rear Projection Television Logo
258 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
